Home » Eclipse Projects » SWTBot » Not able to find swtbot plugin
Not able to find swtbot plugin [message #1066708] Wed, 03 July 2013 21:44 Go to next message
Jiajian Lei is currently offline Jiajian LeiFriend
Member
I installed the SWTBOT plugin just the way as tutorial shows. But when I tried to add
org.eclipse.swtbot.eclipse.core
org.eclipse.swtbot.eclipse.finder
org.eclipse.swtbot.junit4_x
org.hamcrest
org.apache.commons.collections
org.junit4
org.apache.log4j
org.eclipse.ui
to the manifest file, it couldn't find it.
I checked with about/installation details. It does show that my eclipse has these plug ins installed though.
When I tried the exact same thing on a fresh new indigo eclipse (the current RCP development eclipse is Juno), it works as expected.
Please help. Screenshots are attached.
[Updated on: Wed, 03 July 2013 23:01]
Report message to a moderator
Re: Not able to find swtbot plugin [message #1066950 is a reply to message #1066708] Fri, 05 July 2013 08:42 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael IstriaFriend
Which tutorial?
The only right ways to install stuff in Eclipse are using p2 Install UI
(Help > Install New Software) and family (MarketPlace, discovery).
If you're using a target-platform, did you make sure SWTBot is available
in this target-platform?
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Not able to find swtbot plugin [message #1067443 is a reply to message #1066950] Mon, 08 July 2013 18:02 Go to previous messageGo to next message
Member
I followed the toturial here, http://wiki.eclipse.org/SWTBot/UsersGuide
I made SWTBot plugins available to the target platform, but the manifest file still can't recognize the plugins.
Screenshot is attached.
  • Attachment: platform.png
    (Size: 167.55KB, Downloaded 270 times)
Re: Not able to find swtbot plugin [message #1067636 is a reply to message #1067443] Tue, 09 July 2013 17:52 Go to previous messageGo to next message
Member
Nevermind. Problem solved. One of the senior engineers corrected the way I added the plugins to the target platform, and it worked.
Thanks a lot.
Re: Not able to find swtbot plugin [message #1068222 is a reply to message #1067636] Fri, 12 July 2013 18:15 Go to previous messageGo to next message
Sanderson D is currently offline Sanderson DFriend
Having the same problem...can you please post how you solved it? 谢谢!
Re: Not able to find swtbot plugin [message #1069433 is a reply to message #1068222] Mon, 15 July 2013 21:58 Go to previous messageGo to next message
Member
I haven't solved the problem yet. Still waiting for solution...
Re: Not able to find swtbot plugin [message #1779076 is a reply to message #1069433] Tue, 02 January 2018 06:48 Go to previous message
minhang kang is currently offline minhang kangFriend
hi,jajian lei
Did your problem solved? I installed the SWTBot failed through P2,and put plug-in packages to target platform,in IDE installation details list we can see these plugins,but they are not recognized by SWTBot.
Looking forward to your reply,thanks a lot.
Previous Topic:RAP Automation
Next Topic:SWTBot Recorder is not absolute
Current Time: Sat Sep 18 08:44:26 GMT 2021
Powered by FUDForum. Page generated in 0.01533 seconds
