Home » Archived » Buckminster » How to run a MWE2 workflow with buckminster
How to run a MWE2 workflow with buckminster [message #1066261] Mon, 01 July 2013 18:32 Go to next message
Marcel Abou Khalil is currently offline Marcel Abou KhalilFriend
I tried the naive approach of adding the following line to my commands.txt:
launch -l 'myProject/GenerateMyDSL.mwe2.launch'
which resulted in the following error:
Launch configuration type id "org.eclipse.emf.mwe2.launch.Mwe2LaunchConfigurationType" does not exist.
Possible causes:
        Missing specification of a launch type (missing plug-in)
        Incorrect launch configuration XML
So basically my question is: how can I run the MWE2 workflow from within my headless buckminster? Is there a plugin I'm missing?
Re: How to run a MWE2 workflow with buckminster [message #1066294 is a reply to message #1066261] Tue, 02 July 2013 03:16 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Did you install the mwe2 feature into Buckminster?
- thomas
On 2013-07-02 04:41, Marcel Abou Khalil wrote:
> Possible causes:
> missing?
Re: How to run a MWE2 workflow with buckminster [message #1066398 is a reply to message #1066294] Tue, 02 July 2013 12:42 Go to previous messageGo to next message
Thomas Hallgren wrote on Mon, 01 July 2013 23:16
- thomas
How do I install it? Where can I find it? It doesn't seem to be at the buckminster download site:
http://download.eclipse.org/tools/buckminster/headless-4.2/features/?d
Re: How to run a MWE2 workflow with buckminster [message #1066407 is a reply to message #1066398] Tue, 02 July 2013 13:33 Go to previous messageGo to next message
>> - thomas
Try the Kepler repository. Use the buckminster install command.
- thomas
Re: How to run a MWE2 workflow with buckminster [message #1066438 is a reply to message #1066407] Tue, 02 July 2013 16:08 Go to previous messageGo to next message
Thomas Hallgren wrote on Tue, 02 July 2013 09:33
- thomas
Thanks, it seems I'm getting closer. I installed the feature that seemed like the correct one like so:
buckminster install http://download.eclipse.org/releases/kepler org.eclipse.emf.mwe2.language.sdk
Unfortunately when I try to exetucte my MWE2 workflow it finds the correct launcher but I'm getting a bunch of errors regarding UI classes that could not be found. It seems the feature I'm using is not actually headless. Am I using the wrong feature? Is there a feature that provides what I need and that is actually headless?
Re: How to run a MWE2 workflow with buckminster [message #1066455 is a reply to message #1066438] Tue, 02 July 2013 17:27 Go to previous message
>> On 2013-07-02 14:42, Try the Kepler repository. Use the buckminster install command.
>> - thomas
That's a question you'll need to ask the people behind MWE2.
- thomas
Previous Topic:ANN: Buckminster for Kepler
Next Topic:Emma Update
Current Time: Sat Sep 26 09:32:10 GMT 2020
Powered by FUDForum. Page generated in 0.02290 seconds
