Home » Eclipse Projects » BIRT » Length of axis
Length of axis [message #1066194] Mon, 01 July 2013 13:49 Go to next message
Stefan Maus is currently offline Stefan MausFriend
Hi there!
I have a table with a chart in the content row. Now a chart is displayed for every data row.
But every generated chart has a different axis length (one goes from 0 to 1, an other from 0 to 10, a third from 0 to 4 etc).
Is there a way to force the axis to always go from 0 to 20 or so? This way I could compare one chart in the table better to an other.
Re: Length of axis [message #1066900 is a reply to message #1066194] Fri, 05 July 2013 05:57 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
In the chart editor, you can go to the format chart tab, then to the x-axis section, then click on the scale button at the bottom of the section and set the min and max to the values you want.
Hope this helps.
Michael
Developer Evangelist, Silanis
Previous Topic:Hide/Remove unused emitters in viewer
Next Topic:[SOLVED] File XES as a datasource
Current Time: Sun Jan 26 22:19:09 GMT 2020
Powered by FUDForum. Page generated in 0.01608 seconds
