Re: Subprocess reuse [message #1066186 is a reply to message #1066175] |
Mon, 01 July 2013 13:06 |
The "Reusable Sub-Process" that was originally defined in BPMN 1.2 has been replaced by the "Call Activity" in BPMN 2.0. Call Activities act as wrappers for a Global Task or a Process. See section 10.2.6 of the BPMN 2.0 specification for details.
Re: Subprocess reuse [message #1066596 is a reply to message #1066535] |
Wed, 03 July 2013 11:15 |
This feature has not been implemented yet. One way to implement this would be to open an editor for the referenced Process, or the tab of the multipage editor that contains the Process if it is contained in the same file.
Also, the Call Activity is not being rendered properly: if the Call Activity references a Global Task, it should be decorated with the graphic for Global Task; if the called activity is a Process, it should contain the collapse/expand [+] icon.
Can you please open an enhancement request for this?
Thanks!
Bob
FUDForum. Page generated in 0.03865 seconds
