Home » Archived » DSDP - Real-Time Software Components (RTSC) » Source location(Where is the source?)
Source location [message #1066150] Mon, 01 July 2013 05:39 Go to next message
I'm trying to checkout the xdc source tree. I read [1] and tried to download [2] without success. I'm probably missing something, but can't simply checkout following urls :
svn://dev.eclipse.org/svnroot/dsdp/xdc/xdccore
svn://dev.eclipse.org/svnroot/Technology_RTSC/xdc/xdccore
and a lot of variations..
Could someone give me some clue to get the source?
Aurélien
[1] http://wiki.eclipse.org/SVN_Howto#SVN_Repository_Paths
[2] http://dev.eclipse.org/viewsvn/viewvc.cgi/xdc/xdccore/?root=Technology_RTSC
Re: Source location [message #1066250 is a reply to message #1066150] Mon, 01 July 2013 13:27 Go to previous messageGo to next message
Aurélien,
the link I am using is //dev.eclipse.org/svnroot/technology/org.eclipse.rtsc/xdc/xdccore. Can you try that? If it doesn't work, what's the error message you are seeing?
Re: Source location [message #1066321 is a reply to message #1066250] Tue, 02 July 2013 03:40 Go to previous messageGo to next message
Hi Sasha,
Your uri is perfectly working. Thanks a lot!
Re: Source location [message #1727398 is a reply to message #1066150] Tue, 22 March 2016 13:30 Go to previous messageGo to next message
I recently tried to grab a snapshot with svn with no luck using the following on the command line:
$ svn checkout svn://dev.eclipse.org/svnroot/technology/org.eclipse.rtsc/xdc/xdccore
svn: Can't connect to host 'dev.eclipse.org': Connection timed out
Has this changed since the last post?
Thanks!
Re: Source location [message #1727674 is a reply to message #1727398] Thu, 24 March 2016 22:01 Go to previous message
Yes,
eclipse switched to git. Check https://git.eclipse.org/c/rtsc/org.eclipse.rtsc.xdccore.git.
Previous Topic:IPeripheral and driver development
Next Topic:Can't locate source code while debugging GCC Arm device
Current Time: Fri Jul 18 23:10:38 EDT 2025
Powered by FUDForum. Page generated in 1.28388 seconds
