Home » Eclipse Projects » BIRT » Birt viewer 4.3 PPTX
Birt viewer 4.3 PPTX [message #1065923] Fri, 28 June 2013 10:42 Go to next message
Mimmo Rossi is currently offline Mimmo RossiFriend
i tested the new DOCX and PPTX export functionality, it works almost correct because i have a problem, but only in PPTX, on strings of text: the text is splitted into several text boxes.
This to me is a problem in fact customers would like to change the text.
There is a way to create in PPTX a single text box as well as DOCX?
Thanks in advance
Re: Birt viewer 4.3 PPTX [message #1066137 is a reply to message #1065923] Mon, 01 July 2013 08:14 Go to previous messageGo to next message
No solution for this problem?
Re: Birt viewer 4.3 PPTX [message #1066893 is a reply to message #1066137] Fri, 05 July 2013 05:43 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
Sorry for the delay. I think this is the same as it worked in the other emitter as well. This is likely something you'll have to create an enhancement request for. You'd do this in the bugzilla.
Michael
Developer Evangelist, Silanis
Re: Birt viewer 4.3 PPTX [message #1067276 is a reply to message #1066893] Mon, 08 July 2013 08:00 Go to previous messageGo to next message
Hi Micahel,
no problem for the answer; what should I do to enter the request in bugzilla? How it works (someone reporting me when the task is closed)?
Thanks in advance
Re: Birt viewer 4.3 PPTX [message #1067719 is a reply to message #1067276] Wed, 10 July 2013 09:42 Go to previous messageGo to next message
Mimmo Rossi wrote on Mon, 08 July 2013 04:00
Hi Micahel,
Thanks in advance
Hi Michael,
i added a bug in bugzilla that have this id 412493; but what should I do? I have to check it every day or receive some feedback?
[Updated on: Wed, 10 July 2013 09:42]
Report message to a moderator
Re: Birt viewer 4.3 PPTX [message #1068297 is a reply to message #1067719] Fri, 12 July 2013 22:43 Go to previous messageGo to next message
Yeah. When anyone does anything on the bug, you should get an email notification. If you post the bug info in here and others with the same issue stumble across it, they can vote for the bug. Typically the bugs with the most votes get attention along with the critical bugs.
Michael
Re: Birt viewer 4.3 PPTX [message #1076403 is a reply to message #1068297] Wed, 31 July 2013 10:35 Go to previous messageGo to next message
Hi Michael,
i monitor a bug, but its status is Always NEW; i can do something to "highlight" this bug?
In addition to the id of the bug, already indicated, now i insert a link to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412493
Do you think it's enough?
Re: Birt viewer 4.3 PPTX [message #1078516 is a reply to message #1076403] Sat, 03 August 2013 05:18 Go to previous messageGo to next message
Usually the bugs with the most votes get looked at the quickest. You might also post an example so it's easy for them to look at once they do get to your post.
Michael
Re: Birt viewer 4.3 PPTX [message #1079886 is a reply to message #1078516] Mon, 05 August 2013 07:48 Go to previous message
Hi Michael
thanks for your tip, i will insert an example of pptx and doc.
Previous Topic:Barcodes ?
Next Topic:Paint area in Line Chart
Current Time: Sun Sep 20 08:59:18 GMT 2020
Powered by FUDForum. Page generated in 0.01871 seconds
