Home » Eclipse Projects » Gemini » [Solved]Problem with: example(Gemini JPA Sample Configuration Generator waiting for config service...)
[Solved]Problem with: example [message #1065914] Fri, 28 June 2013 10:00 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
Hello, i tried the example org.eclipse.gemini.jpa.sample.basic_1.2.0.M1 and then tried org.eclipse.gemini.jpa.sample.configadmin.gen_1.2.0.M1
(i only repaced the basic activator with the configadmin activator, and added org.osgi.service.cm to included packages)
when i then launch the app i get the following log:
i set start levels for
org.eclipse.gemini.dbaccess.derby: startlevel 2 : autostart true
org.eclipse.gemini.jpa: startlevel 3 : autostart true
org.eclipse.gemini.jpa.sample.basic: startlevel 4 : autostart true
anything i miss?
[Updated on: Tue, 02 July 2013 06:59]
Report message to a moderator
Re: Problem with: example [message #1065956 is a reply to message #1065914] Fri, 28 June 2013 13:24 Go to previous messageGo to next message
Michael Keith is currently offline Michael KeithFriend
Hi Ludwig,
It is waiting for the config service to be registered. Did you also start the framework config admin impl bundle? See the instructions in the GettingStarted.txt file in the distribution to see which additional bundles to start.
-Mike
Re: Problem with: example [message #1065973 is a reply to message #1065956] Fri, 28 June 2013 14:38 Go to previous messageGo to next message
thanks for your help mike.
by following your hints i got the sample working.
then tried to get the sample working in my 'big' application.
it locks my application - need to investigate when or why.
UPDATE: it locks at this position:
final Display display = PlatformUI.createDisplay();
this makes no sense at all, gemini does not touch anything there and the rest of my code is untouched.
[Updated on: Fri, 28 June 2013 15:43]
Re: Problem with: example [message #1065998 is a reply to message #1065914] Fri, 28 June 2013 17:50 Go to previous message
forget it, org.eclipse.equinox.console blocked :-/
Previous Topic:Gemini JPA 1.1 and EclipseLink 2.5
Next Topic:[Solved!] ConfigAdmin Example error
Current Time: Fri Apr 10 10:30:39 GMT 2020
Powered by FUDForum. Page generated in 0.07077 seconds
