Home » Eclipse Projects » Hudson » Build Triggers Updated by Hudson/Maven Integration?
Build Triggers Updated by Hudson/Maven Integration? [message #1065479] Tue, 25 June 2013 21:33 Go to next message
Shelli Orton is currently offline Shelli OrtonFriend
I have set up my Maven build jobs with the following config properties checked:
- Notify that Maven dependencies have been updated by Maven 3 integration
- Build when Maven dependencies have been updated by Maven 3 integration
I've noticed that someone/thing has since checked these properties and added the up/downstream project names in the text boxes:
- Build other projects
- Build after other projects are built
I've canvassed my team and they all say that they didn't make these updates. Does Hudson automatically set/update these based on the Maven 3 integration settings?
Re: Build Triggers Updated by Hudson/Maven Integration? [message #1065482 is a reply to message #1065479] Tue, 25 June 2013 21:52 Go to previous messageGo to next message
Bob Foster is currently offline Bob FosterFriend
Member
I don't think so, but I'm not sure. If you uncheck them, do they come back?
Re: Build Triggers Updated by Hudson/Maven Integration? [message #1065484 is a reply to message #1065482] Tue, 25 June 2013 22:38 Go to previous message
Yes, they do. But I'm not sure if it's someone on the team not understanding to not manually update them or if Hudson is doing it. I'd like to confirm if it's Hudson or not before delving further with the team.
Previous Topic:Job Import Plugin
Next Topic:Hudson Can't Find Snapshot in Nexus
Current Time: Wed Dec 02 13:58:25 GMT 2020
Powered by FUDForum. Page generated in 0.01872 seconds
