Could not load the method for the property name [message #1065279] |
Tue, 25 June 2013 08:34 |
Hannes Kühtreiber Messages: 21 Registered: June 2013 |
Junior Member |
Hello Everybody,
after doing a successful test project (www.vogella.com/articles/JavaPersistenceAPI/article.html) I tried to move on to my DB, but Predeployment of the PersistenceUnit fails.
I am getting Exception [EclipseLink-28018] and [EclipseLink-7216]
Quote: Could not load the method for the property name [guid] on the class [class core.lumo.biooffice.ContactImpl]
Ensure there is corresponding get method for that property name defined on the class.
I get this message for the first attribute in the orm.xml, it does not matter if it is the id or not.
The class has getters and setters for all properties.
In the orm.xml I tried
<orm:access>FIELD</orm:access>
as well as
<orm:access>PROPERTY</orm:access>
what else could be the reason? Or is this error code misleading and something else is amiss?
Hannes
FUDForum. Page generated in 0.02501 seconds
