Workbench.xmi fails to load [message #1065250] |
Tue, 25 June 2013 06:27 |
Bastian Wagenfeld Messages: 183 Registered: January 2013 |
I get this exception for a little while, but never needed to use any persisted state. But now, I want to use the getPersistedState-method of parts. Unfortunately the workbench.xmi isn't created correctly. Anyway it fails to load with the following exception:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-06-25 08:09:57.466
!MESSAGE Unable to load resource file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null)' is not legal. (file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 587, 277)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:234)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:202)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:370)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:220)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:557)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at de.cmp.test.main.e3.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null)' is not legal. (file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 587, 277)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2643)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XMLHandler.java:2814)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2716)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2188)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2091)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:128)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1835)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1018)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:81)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:996)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:707)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:506)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1323)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:302)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 23 more
Caused by: java.lang.IllegalArgumentException: The selected element org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null) is not a child of this container
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:158)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.eSet(ElementContainerImpl.java:234)
at org.eclipse.e4.ui.model.application.ui.impl.GenericTileImpl.eSet(GenericTileImpl.java:119)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2653)
... 54 more
The RCP has one main Application.e4xmi and about eight fragments with one perspective per fragment.
I added the workbench.xmi to this post. I'd be really glad to get a hint on that.
Best regards
Bastian
[Updated on: Tue, 25 June 2013 06:40] Report message to a moderator
Re: Workbench.xmi fails to load [message #1065308 is a reply to message #1065253] |
Tue, 25 June 2013 09:52 |
I'm sorry, but although I found out what I did wrong, I still won't get the workbench.xmi to be loaded correctly.
If the application starts the first time (and no workbench.xmi is available) all fragments are included. Then I exit the RCP and the workbench.xmi gets written. When I restart the app the following error occurs:
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-06-25 11:20:39.232
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
at org.eclipse.e4.ui.model.internal.ModelUtils.getContainingContext(ModelUtils.java:181)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getContainingContext(ModelServiceImpl.java:280)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.getContext(PartRenderingEngine.java:674)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:727)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at de.cmd.test.main.e3.Application.start(Application.java:20)
This seems to happen, since the xmi:id's ind the workbench.xmi are different from the xmi:id's in the Application.e4xmi. The id's from the included fragments are the same as in the workbench.xmi.
So my question is: How can it happen that there are different id's used in the workbench.xmi than in the Application.e4xmi?
Best regards and thanks for help
Bastian
[Updated on: Tue, 25 June 2013 10:30] Report message to a moderator
Re: Workbench.xmi fails to load [message #1244050 is a reply to message #1065308] |
Tue, 11 February 2014 21:04 |
Edmund Reinhardt Messages: 8 Registered: January 2012 |
Junior Member |
We are experiencing a similar exception in Eclipse 4.2 extended by Rational Developer for i v 9.0
From the .log:
!MESSAGE Unable to load resource file:/C:/Users/ekomeshak/IBM/rationalsdp/workspace/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@49bbb05 (elementId: PartStack@2abada0b, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null)' is not legal. (file:/C:/Users/ekomeshak/IBM/rationalsdp/workspace/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 3411, 1)
Very interested in updates as customer is pushing for resolution.
FUDForum. Page generated in 0.04146 seconds
