Home » Archived » Buckminster » Validate WSDL Ant Task
Validate WSDL Ant Task [message #1065073] Mon, 24 June 2013 08:49 Go to next message
Jakob Braeuchi is currently offline Jakob BraeuchiFriend
Member
hi,
i have the following ant-script to validate a WSDL
	<path id="validation.class.path">
		<fileset dir="${eclipse.home}/plugins">
			 <include name="**/*.jar"/>
		</fileset>
	</path>
	<taskdef name="wsdl.validate" classname="org.eclipse.wst.wsdl.validation.internal.ui.ant.WSDLValidate">
		<classpath refid="validation.class.path" />
	</taskdef>
	<target name="validate.wsdl">
		<property name="wsdl.file" value="${wsdl.name}" />
		<echo message="Validate WSDL: ${wsdl.file}"/>
		<wsdl.validate file="${wsdl.file}"/>
	</target>
This ant script is called from a Buckminster Action.
When invoking the action i get this error:
[ant] ERROR 13:62:cvc-elt.1: Cannot find the declaration of element 'wsdl:definitions'.
When i validate the WSDL using Context Menu->Validate it works.
I also wrote a Buckminster Actor in Java to validate the WSDL using org.eclipse.wst.wsdl.validation.internal.eclipse.WSDLValidator .
Invoking this actor from an action also works.
What's wrong with the ant actor here ?
thanks
jakob
see http://www.eclipse.org/forums/index.php/t/489318/
Re: Validate WSDL Ant Task [message #1065101 is a reply to message #1065073] Mon, 24 June 2013 11:34 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
It looks as though it finds the WSDLValidate class OK but then the task fails somehow. Where is the reference to
'wsdl:definitions' declared?
- thomas
On 2013-06-24 10:49, Jakob Braeuchi wrote:
> hi,
> </fileset>
> </path>
> </taskdef>
> </target>
> thanks
> jakob
Re: Validate WSDL Ant Task [message #1065113 is a reply to message #1065101] Mon, 24 June 2013 12:17 Go to previous messageGo to next message
Member
hi thomas,
this is at the beginning of the WSDL:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wsdl:definitions xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
	xmlns:tns="http://www.example.org/NewWSDLFile/" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
	xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="NewWSDLFile"
	targetNamespace="http://www.example.org/NewWSDLFile/">
additional hint:
when i was debugging my java-actor (started an eclipse within an eclipse) i also got the cvc-elt error. same happened when i was debugging the context-menu action.
after exporting the bundle containing the java-actor into the dropins-folder the WSDL validated fine.
jakob
[Updated on: Mon, 24 June 2013 12:29]
Report message to a moderator
Re: Validate WSDL Ant Task [message #1065128 is a reply to message #1065113] Mon, 24 June 2013 13:07 Go to previous messageGo to next message
My guess is that it doesn't find this file at all. You echo the value of ${wsdl.file} just before the call. Does it show
the correct (full) path?
- thomas
On 2013-06-24 14:17, Jakob Braeuchi wrote:
> hi thomas,
> jakob
Re: Validate WSDL Ant Task [message #1065136 is a reply to message #1065128] Mon, 24 June 2013 13:26 Go to previous messageGo to next message
Member
this is the output:
[start ch.rtc.jabas.esb.test.srv2.interfaces:osgi.bundle$1.0.0.qualifier#ws.validate.ant]
[ant] Validate WSDL: src/java/ch/rtc/jabas/esb/test/srv2/neutral/impl/NewWSDLFile.wsdl
[ant] ---------------------------------------
[ant] Validating file:///C:/Eclipse_Workspaces/Jabas_ESB/plugins/ch.rtc.jabas.esb.test.srv2.interfaces/src/java/ch/rtc/jabas/esb/test/srv2/neutral/impl/NewWSDLFile.wsdl - INVALID
[ant] ERROR   5:56:cvc-elt.1: Cannot find the declaration of element 'wsdl:definitions'.
[ant]
[end ch.rtc.jabas.esb.test.srv2.interfaces:osgi.bundle$1.0.0.qualifier#ws.validate.ant]
"Validate WDSL" comes from my ANT-Actor, "Validating file" from the ANT-Task i suppose.
The file can be found. I slightly modified it (replaced "wsdl:definitions" with "Xwsdl:definitions"), then I get the following errors:
[ant] ERROR   5:56:The prefix "Xwsdl" for element "Xwsdl:definitions" is not bound.
[ant]
[Updated on: Mon, 24 June 2013 13:27]
Re: Validate WSDL Ant Task [message #1065139 is a reply to message #1065136] Mon, 24 June 2013 13:37 Go to previous messageGo to next message
Member
i added a small sample containing a WSDL, the ANT-Script and the CSPEX.
[Updated on: Mon, 24 June 2013 13:42]
Re: Validate WSDL Ant Task [message #1065164 is a reply to message #1065136] Mon, 24 June 2013 14:37 Go to previous messageGo to next message
On 2013-06-24 15:26, Jakob Braeuchi wrote:
> this is the output:
> [ant] Validating
> - INVALID
> [ant] [end ch.rtc.jabas.esb.test.srv2.interfaces:osgi.bundle$1.0.0.qualifier#ws.validate.ant]
> The file can be found. I slightly modified it (replaced "wsdl:definitions" with "Xwsdl:definitions"), the I get the
> following errors:
> [ant] Validating
> - INVALID
Ok, so the taskdef is bound (which is Buckminster and Ants responsibility with respect to class loaders and such), the
file parameter is passed on correctly and the task starts OK. I'm afraid that what happens after that is beyond what I
can help out with.
- thomas
Re: Validate WSDL Ant Task [message #1065269 is a reply to message #1065164] Tue, 25 June 2013 08:03 Go to previous message
Member
hi thomas,
i can reproduce the problem with a plain ANT-script (no Buckminster involved). So I'll try to get an answer from WTP.
the idea was to validate the WSDL before generating the artifacts. This does not work because of the ANT problems; so I decided to force validation of the WSDL whenever it is saved with a builder defined in .project.
jakob
Previous Topic:CQuery import issues on Mac using SVN reader
Next Topic:Buckminster does not resolve fragment host plugin
Current Time: Fri Jan 24 02:23:23 GMT 2020
Powered by FUDForum. Page generated in 0.02401 seconds
