Re: Feature type does not exist on java [message #1271626 is a reply to message #1065189] |
Sat, 15 March 2014 18:11 |
keynne Belle Messages: 30 Registered: January 2013 |
Member |
Hello.
I successively re-tried to generate the KDM of the same project that generated the exception above. For this purpose, I used Kepler, Juno, and Indigo with MoDisco 0.9.2, 0.11 and finally 0.12. However, this time i deleted all the non .java files from the analyzed project. The generation of the KDM could still not be achieved and with Kepler and MoDisco 0.12 it ended with the following exception : org.eclipse.m2m.atl.engine.vm.VMException: Feature type does not exist on java!SingleVariableAccess
at A.CreateUsesType(1 : Mjava!TypeAccess;) : ??#32(javaToKdm.atl[1886:10-1886:18])
local variables = {tgt=OUT!<unnamed>, src=IN!<unnamed>, self=javaToKdm : ASMModule}
local stack = [OUT!<unnamed>, OUT!<unnamed>, javaToKdm : ASMModule]
A similar bug has been submitted 2 years ago on the following link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=351837 . Do you know if a fix has been found since? Is there something I should modify in the analyzed project to resolve that issue?
Thank you in advance for your reply.
[Updated on: Sat, 15 March 2014 18:13] Report message to a moderator
FUDForum. Page generated in 0.02578 seconds
