Home » Eclipse Projects » BIRT » Disable LOG
Disable LOG [message #1064920] Fri, 21 June 2013 16:14 Go to next message
Mimmo Rossi is currently offline Mimmo RossiFriend
How can completely disable the log? I set in the web.xml
BIRT_VIEWER_LOG_LEVEL = OFF
but doesn't work.
What is wrong?
Re: Disable LOG [message #1065233 is a reply to message #1064920] Mon, 24 June 2013 23:26 Go to previous messageGo to next message
Kristopher Clark is currently offline Kristopher ClarkFriend
Can you check your logging.properties file? In it you should find a .level which can be changed to SEVERE or WARNING.
Re: Disable LOG [message #1081420 is a reply to message #1065233] Wed, 07 August 2013 07:59 Go to previous message
i have birt 2.1.0 and i could not find the file logging.properties?
Where should I look for?
There would be other solutions?
Previous Topic:Passing parameters to report
Next Topic:org.eclipse.datatools.connectivity.oda.OdaException
Current Time: Sat Feb 22 01:06:05 GMT 2020
Powered by FUDForum. Page generated in 0.02695 seconds
