Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1087405 is a reply to message #1065339] |
Thu, 15 August 2013 15:40 |
Adolfo Sanchez-Barbudo Herrera Messages: 260 Registered: July 2009 |
Hi Steffen,
Today I've tried the Eclipse Gerrit connection and it worked for me after updating my Mylyn/Gerrit connector.
However, I identify some authoring failures yet. Basically the Review editor doesn't allow me to modify the code review state(assign reviewers, publish comments, etc). It looks like I was no authored to do so, so I can only do read-only operations like see attributes, open the compare-editor on patch set files, etc.
Have you received any issue related to this? May I be missing some other configuration bit ? (I've properly set my credentials in the Task Repository view), otherwise should I raise a bugzilla ?
Adolfo.
FUDForum. Page generated in 0.04275 seconds
