Home » Eclipse Projects » Rich Client Platform (RCP) » Pulldown menu: display label of a command
Pulldown menu: display label of a command [message #1064799] Fri, 21 June 2013 03:41 Go to next message
In a contributed toolbar, I contributed a pulldown menu with two commands contributed in the pulldown menu. When I click on a command contributed in the menu, I want to display the label of this command close to pulldown arrow.
1. Is it possible to do this ?
I have another problem with my contributed pulldown menu. I have no icon associated with it. So by default, the label of the pulldown menu is displayed. All others commands (which have icons) contributed in the same toolbar take the same width as the pulldown menu ! It is ugly.
2. Is it possible to set the size of the contributed commands widgets in a contributed toolbar ?
Re: Pulldown menu: display label of a command [message #1064868 is a reply to message #1064799] Fri, 21 June 2013 09:23 Go to previous messageGo to next message
On 06/21/2013 09:09 AM, Axel RICHARD wrote:
You might have to try something with
org.eclipse.jface.window.DefaultToolTip.
The icons take the same width as your label? Or the same height? Could
you please attach a small snapshot?
There's no way to control the size of contributed toolitem widgets.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/workbench.htm
Re: Pulldown menu: display label of a command [message #1064872 is a reply to message #1064868] Fri, 21 June 2013 09:38 Go to previous messageGo to next message
It's the same height, but the width is also modified.
I attached two screenshots : one without dropdown menu, and one with dropdown. One this with dropdown, you can see that all widgets contributed in toolbar have their height and wdth modified compare to this without dropdown.
Re: Pulldown menu: display label of a command [message #1064889 is a reply to message #1064872] Fri, 21 June 2013 10:10 Go to previous messageGo to next message
Thanks. There's no way to modify the height yourself (and that's what's
effecting the width). I'd replace it with an icon.
PW
Paul Webster
Re: Pulldown menu: display label of a command [message #1064892 is a reply to message #1064889] Fri, 21 June 2013 10:19 Go to previous message
Ok, thanks a lot for your help.
Previous Topic:Child menu of New menu is not showing In E4 RCP.
Next Topic:Reset perspective though command for perspective created by application model not showing any part i
Current Time: Fri Apr 25 19:30:23 EDT 2025
Powered by FUDForum. Page generated in 0.06066 seconds
