Home » Modeling » OCL » OCL Editor(How to model a OCL model?)
OCL Editor [message #1064630] Thu, 20 June 2013 06:09 Go to next message
Hi.
I am looking for a way to model OCL invariants (e.g., for Ecore models) like an ordinary model using the tree-based EMF instance editor. Is there a way to do this? If so, which OCL meta model (which nsURI) do I have to use?
Thorsten
Re: OCL Editor [message #1064688 is a reply to message #1064630] Thu, 20 June 2013 10:33 Go to previous messageGo to next message
Hi Throsten,
If you want to embed OCL constraints within your Ecore models, Follow
this tutorial:
http://help.eclipse.org/juno/topic/org.eclipse.ocl.doc/help/Tutorials.html?cp=49_3_0#OCLinEcoreTutorial
If you prefer a separate OCL document with your constraints, follow the
following one:
http://help.eclipse.org/juno/topic/org.eclipse.ocl.doc/help/CompleteOCLTutorial.html?cp=49_3_2
NB: There is a lot of interesting documentation in the Eclipse OCL help
Adolfo.
> have to use?
Re: OCL Editor [message #1065115 is a reply to message #1064688] Mon, 24 June 2013 08:19 Go to previous messageGo to next message
Thank you, Adolfo, for the response. But I think this is not the point I am looking for. What I want to do is:
1. Model an OCL expression/invariant for an element (EClass) within an xy.ecore model.
2. Model a transformation from OCL to an other constraints language (constr.ecore) using a model2model-transformation engine like Henshin or ATL.
3. Transform the expression from (1) to an instance of constr.ecore by using the transformation from (2).
Therefore, I need some ways to model the expression in (1) in a more abstract way (the AST) and to use the corresponding nsURI in step (2).
Thorsten
Re: OCL Editor [message #1065165 is a reply to message #1065115] Mon, 24 June 2013 10:49 Go to previous messageGo to next message
Hi Throsten,
You have the classic Ecore-binded OCL metamodel at
org.eclipse.ocl.ecore/model
You have the new Pivot-based OCL metamodel at
org.eclipse.ocl.examples.pivot/model
You can import sources from your Eclipse installation or use the GIT
repository [1]
I hope this helps.
Adolfo.
[1] git://git.eclipse.org/gitroot/mdt/org.eclipse.ocl.git
> xy.ecore model.
> ATL.
> Best regards,
> Thorsten
Re: OCL Editor [message #1065175 is a reply to message #1065115] Mon, 24 June 2013 11:15 Go to previous messageGo to next message
HI
> xy.ecore model.
You probably want to do this using the OCLinEcore editor.
> or ATL.
There is currently no direct exposure of a coherent Ecore + OCL AST that
can be loaded directly by another tool,
[Within the OCLinEcore editor there is a SaveAs Pivot option, but I can
just about guarantee that while it may save the result it will not be
loadable; https://bugs.eclipse.org/bugs/show_bug.cgi?id=402780]
.... so you need to load the *.ecore into memory yourself.
As Adolfo mentioned you can use the classic functionality to load the
*.ecore as an Ecore model and perhaps then use some of the
....ecore.delegate to convert each OCL text expression to its AST.
Or you can use the pivot functionality to load the *.ecore as an Ecore
model, perform an OCL.ecore2pivot() conversion for the resource (the OCL
text will be in the form of OpaqueExpression). You can use
PivotUtil.getExpressionInOCL to promote these to AST form.
> Best regards,
> Thorsten
Re: OCL Editor [message #1065221 is a reply to message #1065175] Mon, 24 June 2013 16:36 Go to previous messageGo to next message
Hi Ed.
Nice to hear from you! Do you remember me? I am the EMF Refactor guy that talked to you at ECE2012 in Ludwigsburg.
Thanks for your answers. Here are my comments:
>> xy.ecore model.
OK. I will do this.
But I can import and use the pivot model within a transformation rule, can't I?
You mean, I need to load the *.ecore file consisting of the structure model AND the OCL invariants (modeled using the OCLinEcore editor) programmatically as usual in EMF?
Hm. Class 'org.eclipse.ocl.examples.pivot.utilities.PivotUtil' does not have such method 'getExpressionInOCL()'...
Thorsten
Re: OCL Editor [message #1065249 is a reply to message #1065221] Tue, 25 June 2013 02:22 Go to previous messageGo to next message
On 24/06/2013 21:36, Thorsten Arendt wrote:
> Hi Ed.
Oh Yes. How's the integration with Xtext doing? With QVTd progressing,
I'm increasingly interesrting in adding transformatyion-defined
refactorings to editors.
>> that can be loaded directly by another tool,
> can't I?
Pivot.ecore is an ordinary Ecore model, so you can use the Pivot
meta-model as any other Ecore meta-model.
The difference is that the Pivot Model is usually loaded from something
defined against the Ecore or UML meta-models.
Yes. The OCL will be embedded in EAnnotations.
>> OCL text will be in the form of OpaqueExpression). You can use
It's new in Kepler, making previous delegate/test functionality more
available to the code generator.
Ed
Re: OCL Editor [message #1065791 is a reply to message #1065249] Thu, 27 June 2013 09:35 Go to previous messageGo to next message
Hi Ed.
I just presented a preliminary version at EclipseDemoCamp in Bonn last week. The refactoring functionality does what it is supposed to be. But unfortunately I have to cope with problems concerning the layout. If I will have time I try to fix it. Perhaps I present it at EclipseConEurope 2013.
OK. This works...
Unfortunately, the OCL.ecore2pivot() conversion raises an exception with the following stack trace:
Exception in thread "main" org.eclipse.ocl.examples.pivot.utilities.IllegalLibraryException: No OCL Standard Library content available
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getRequiredLibraryType(PivotStandardLibrary.java:278)
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.resolveRequiredSimpleType(PivotStandardLibrary.java:377)
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getBooleanType(PivotStandardLibrary.java:127)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.initializeEcore2PivotMap(Ecore2Pivot.java:482)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getEcore2PivotMap(Ecore2Pivot.java:326)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveDataType(Ecore2Pivot.java:612)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveType(Ecore2Pivot.java:667)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.update(Ecore2Pivot.java:749)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.importObjects(Ecore2Pivot.java:467)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getPivotRoot(Ecore2Pivot.java:412)
	at org.eclipse.ocl.examples.pivot.OCL.ecore2pivot(OCL.java:385)
Here is also my code. What am I doing wrong?
// Convert resource (OCL text in EAnnotations => OpaqueExpression)
		OCL ocl = OCL.newInstance();
		ocl.initialize(resourceSet);
		try {
			ocl.ecore2pivot(petrinetResource);
		} catch (ParserException e) {
			e.printStackTrace();
Thorsten
Re: OCL Editor [message #1065836 is a reply to message #1065791] Thu, 27 June 2013 12:50 Go to previous messageGo to next message
I refreshed the relevant description in the Kepler OCL Documentation.
Search for "No OCL Standard Library content available"
Ed Willink
Re: OCL Editor [message #1065919 is a reply to message #1065836] Fri, 28 June 2013 06:28 Go to previous messageGo to next message
Hi Ed!
Thanks for the docu. Now I can translate a textual description of the OCL invariant within an EAnnotation to (1) a textual description within an OpaqueExpression, and then (2) to the AST representation of an ExpressionInOCL. Afterwards I replace the OpaqueExpression by the ExpressionInOCL. This is exactly what I want. But...
After persisting the resource as a *.pivot, there are problems when opening it both via the sample reflective editor and by API. For each 'ownedType' within a package I get an IllegalValueException:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.ocl.examples.pivot.internal.impl.TypeImpl' is not legal. (platform:/resource/PetriNet/model/PetriNet-converted-changed.pivot, 6, 149)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2671)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2656)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2174)
Caused by: java.lang.ArrayStoreException
This really confuses me... any help?
Thorsten
Re: OCL Editor [message #1065932 is a reply to message #1065919] Fri, 28 June 2013 07:32 Go to previous message
I raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=402780 to major
in response to a similar query a couple of days ago.
I am currently working on the direct generation of the Pivot meta model
from UML 2.5 and other metamodels. This should lead on to solving the
loadability.
Ed Willink
On 28/06/2013 11:28, Thorsten Arendt wrote:
> Hi Ed!
> 6, 149)
> at
> at
> at
> Regards,
> Thorsten
Previous Topic:[Announce] Eclipse OCL 4.1.0 (Kepler) is available.
Next Topic: Return OrderedSet{null} for many features
Current Time: Thu May 15 09:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.05110 seconds
