Home » Eclipse Projects » SWTBot » How to click a button under a CTabFolder?
How to click a button under a CTabFolder? [message #1064567] Wed, 19 June 2013 19:21 Go to next message
Can someone help me with the code on how to click this "Import data structure..." button under a CTabFolder.(Pic Attached)
  • Attachment: Capture.JPG
    (Size: 47.56KB, Downloaded 388 times)
Re: How to click a button under a CTabFolder? [message #1065264 is a reply to message #1064567] Tue, 25 June 2013 03:42 Go to previous messageGo to next message
You can use the Simple
bot.button(buttonTitle).click();
Try to get the label of the Button which should be in your case is Import data structure ...
So Code must be
bot.button("Import data structure ...").click();
Re: How to click a button under a CTabFolder? [message #1421089 is a reply to message #1065264] Wed, 10 September 2014 19:22 Go to previous message
thanks pawan.It helped.
Previous Topic:[Maven/Tycho] First editor activation event not delivered?
Next Topic:How to get failed test cases in the middle.
Current Time: Fri Jun 20 07:40:01 EDT 2025
Powered by FUDForum. Page generated in 0.07259 seconds
