Home » Modeling » EMF » Storing POJOs in an EMF Resource
Re: Storing POJOs in an EMF Resource [message #1064687 is a reply to message #1064581] |
Thu, 20 June 2013 14:20 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Ed Merks wrote on Thu, 20 June 2013 02:04Eric,
You'd need to do it as an EDataType, so you could do something like
what's done for EJavaObject which just wraps java.lang.Object or do
something more specific for with more knowledge of the type in
question. In either case, you need to write all the logic to do the
<value> <-> String conversion.
Ed,
I've never had to define an EDataType, so I'm trying to wrap my head around what you're saying. Doing a little research, it seems that EJavaObject doesn't exist; web searches find only passing references to it and Eclipse doesn't know anything about it (EMF SDK is part of my target platform). Can you provide any direct pointers?
I should also mention that I'm trying to find a way to do this generically, in a framework that encapsulates EMF persistence. Right now, I allow clients to define their own EMF model types (that extend an interface I have defined) and I persist those when I encounter them. I have a need to eliminate the requirement that these objects be EMF-based; I need to be able to persist any arbitrary POJO that I encounter as long as it implements the interface. I'd love to see some examples of defining an EDataType dynamically, icing on the cake would be something that is equally generic to what I need, but a concrete example can probably get me far enough to make the leap to generic/dynamic.
For example, if I encounter an instance of the following class, how do I go about serializing it (and subsequently deserializing)?
public class SomeData implements GenericInterface {
private boolean someBoolean;
private String someString;
public boolean getSomeBoolean() { return someBoolean; }
public String getSomeString() { return someString; }
// assume setters, etc.
Thanks in advance for any pointers,
Eric
Quote:On 19/06/2013 11:34 PM, Eric Rizzo wrote:
> Is there a straightforward technique for storing POJOs (object that
> don't extend EObject) in a Resource? I tried googling but didn't find
> anything useful using various combinations of search terms.
> The only idea I can think of is doing a simple EMF model that wraps
> any Object, and persist that. But that seems a bit crude to me. Is
> there any better way?
Re: Storing POJOs in an EMF Resource [message #1064723 is a reply to message #1064687] |
Thu, 20 June 2013 16:27 |
Ed Merks Messages: 33113 Registered: July 2009 |
Eric,
Comments below.
>> Eric,
> Ed,
It's an EDataType in Ecore.ecore. The important methods to implement
for an EDataType are the ones in XyzFactoryImpl. You'll get the idea
looking at methods like
org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createEJavaObjectFromString(EDataType,
String).
> generic/dynamic.
The best I can do is point you at something like EcoreFactoryImpl.
There's nothing in such an interface to help you create a new instance
of the same kind given an existing instance (knowing nothing of what
GenericInterface might help provide).
> Eric
> Quote:
>> find > anything useful using various combinations of search terms.
Ed Merks
Re: Storing POJOs in an EMF Resource [message #1065727 is a reply to message #1064723] |
Thu, 27 June 2013 09:37 |
Simon Goodall Messages: 35 Registered: July 2009 |
Member |
I've seen something like this for objects implementing Serializable. You
can create an EMF DataType for Serializable, then in your XyzFactoryImpl
convert to string method you can serialize the object and Base64 encode
it. You can perform the reverse to get it back again.
It's not necessarily the most efficient way of storing the object, but
requires little extra work to persist things. Of course you need to be
careful about changing those classes to avoid breaking the deserialization.
Simon
On 20/06/2013 17:27, Ed Merks wrote:
> Eric,
> Comments below.
>>> Eric,
>> Ed,
> String).
>> generic/dynamic.
>> Eric
>> Quote:
Re: Storing POJOs in an EMF Resource [message #1065730 is a reply to message #1065727] |
Thu, 27 June 2013 09:42 |
Simon,
Yes, that's what EJavaObject does.
On 27/06/2013 11:37 AM, Simon Goodall wrote:
> You can create an EMF DataType for Serializable, then in your
> XyzFactoryImpl convert to string method you can serialize the object
> and Base64 encode it. You can perform the reverse to get it back again.
> deserialization.
> Regards,
> Simon
>> Eric,
>> Comments below.
>>>> Eric,
>>> Ed,
>> String).
>>> generic/dynamic.
>>> Eric
>>> Quote:
Ed Merks
Current Time: Thu Mar 28 11:16:02 GMT 2024
Powered by FUDForum. Page generated in 0.02287 seconds
