Home » Eclipse Projects » Sapphire » CountConstraint does not show any error message
CountConstraint does not show any error message [message #1064089] Mon, 17 June 2013 14:51 Go to next message
kon f is currently offline kon fFriend
Hey,
trying to use some count constraint on my root element - somehow it does not show any error message if the constraint is violated.
import org.eclipse.sapphire.modeling.IModelElement;
import org.eclipse.sapphire.modeling.ListProperty;
import org.eclipse.sapphire.modeling.ModelElementList;
import org.eclipse.sapphire.modeling.ModelElementType;
import org.eclipse.sapphire.modeling.annotations.CountConstraint;
import org.eclipse.sapphire.modeling.annotations.GenerateImpl;
import org.eclipse.sapphire.modeling.annotations.Label;
import org.eclipse.sapphire.modeling.annotations.Type;
import org.eclipse.sapphire.modeling.xml.annotations.XmlBinding;
import org.eclipse.sapphire.modeling.xml.annotations.XmlListBinding;
import org.eclipse.sapphire.modeling.xml.annotations.XmlNamespace;
import org.eclipse.sapphire.modeling.xml.annotations.XmlSchema;
@GenerateImpl
@XmlNamespace(uri = "http://www.example.org/TestSystem")
@XmlSchema(namespace = "http://www.example.org/TestSystem", location = "http://www.example.org/TestSystem/1.0")
@XmlBinding(path = "root")
public interface Root extends IModelElement {
    ModelElementType TYPE = new ModelElementType(Root.class);
    // *** Description ***
    // @formatter:off
    @CountConstraint(min = 1)
    @Type(base = DescriptionBase.class, possible = { DescriptionA.class, DescriptionB.class, DescriptionC.class, DescriptionD.class })
    @XmlListBinding
        path = "descriptions",
        mappings =
                @XmlListBinding.Mapping(element = "a", type = DescriptionA.class),
                @XmlListBinding.Mapping(element = "b", type = DescriptionB.class),
                @XmlListBinding.Mapping(element = "c", type = DescriptionC.class),
                @XmlListBinding.Mapping(element = "d", type = DescriptionD.class)
    ListProperty PROP_DESCRIPTION_BASE = new ListProperty(TYPE, "DescriptionBase");
    ModelElementList<DescriptionBase> getDescriptionBase();
    // @formatter:on
    // *** Item ***
    @Type(base = Item.class)
    @Label(standard = "items")
    @XmlListBinding(mappings = @XmlListBinding.Mapping(element = "item", type = Item.class))
    ListProperty PROP_ITEMS = new ListProperty(TYPE, "Items");
    ModelElementList<Item> getItems();
If I start with some plain xml file, no error message is given. Both list properties violate the constraint since both have zero children.
http://img843.imageshack.us/img843/9696/m1n.png
The strange part is, that I already use the count constraint on list properties in my application. It is further down in the hierarchy (in the Item.class). Apparently, the count constraint just doesn't work on the root element. Or am I doing something wrong? Thank you.
Kon
Re: CountConstraint does not show any error message [message #1064104 is a reply to message #1064089] Mon, 17 June 2013 16:14 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
Strange. Could you open a bug report and attached a zip of a project showing the problem?
Re: CountConstraint does not show any error message [message #1064211 is a reply to message #1064104] Tue, 18 June 2013 09:35 Go to previous messageGo to next message
Hey Konstantin,
I added a bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=410998
Thank you.
Kon
Re: CountConstraint does not show any error message [message #1074166 is a reply to message #1064211] Fri, 26 July 2013 08:09 Go to previous messageGo to next message
Hey,
I'm updated my editor to Sapphire 0.7 having still the same issue. I was wondering if I could use EL to validate the min size of a list property on the root element. I tried the following update on the items property:
// *** Item ***
//@CountConstraint(min = 1)
@Validation(rule = "${Items.Size > 0}", message = "Min. one elemente!", severity = Severity.ERROR)
My problem remains Sad Am I using it right? Thank you.
Kon
Re: CountConstraint does not show any error message [message #1112347 is a reply to message #1074166] Thu, 19 September 2013 13:18 Go to previous messageGo to next message
Hey Konstantin,
thank you for the bug fix. With the latest version the error messages are shown as expected.
With the change to 0.7 I noticed that the bundle org.eclipse.sapphire.ui.swt.xml.editor now lists the following dependency:
org.eclipse.jdt.core;bundle-version="[3.7.0,4.0.0)"
I was wondering why this jdt dependencies is required? So far, I was able to avoid any jdt bundles in my application Smile
Thank you.
Kon
Re: CountConstraint does not show any error message [message #1112378 is a reply to message #1112347] Thu, 19 September 2013 15:25 Go to previous messageGo to next message
Could you open a bug for this? I am sure the jdt dependency can be factored out.
Re: CountConstraint does not show any error message [message #1112395 is a reply to message #1064089] Thu, 19 September 2013 16:26 Go to previous messageGo to next message
Hey Konstantin,
I created a bug request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=417610
Kon
[Updated on: Thu, 19 September 2013 16:26]
Report message to a moderator
Re: CountConstraint does not show any error message [message #1112400 is a reply to message #1112395] Thu, 19 September 2013 16:32 Go to previous message
Oops. I had already opened a bug since I had a fix in hand. Was about to post a link. Smile
https://bugs.eclipse.org/bugs/show_bug.cgi?id=417608
Please verify.
Previous Topic:Expensive @NoDuplicates
Next Topic:using combobox for non-enums fields
Current Time: Mon Jan 20 17:00:50 GMT 2020
Powered by FUDForum. Page generated in 0.02999 seconds
