Home » Eclipse Projects » Virgo » Using bundles with Wars(Virgo Web Apps)
Using bundles with Wars [message #1063886] Fri, 14 June 2013 18:21 Go to next message
David Cleary is currently offline David ClearyFriend
I'm new to Virgo and OSGi. I have an existing Servlet application that runs on Tomcat. I want to move this application to VTS and let it have access to OSGi based services that I've created.
What is the recommended approach for a Web app to gain references to services? I have little to no experience with Spring, and we are looking to stay as close to OSGi standards as possible to allow us to run in different servers.
Dave
Re: Using bundles with Wars [message #1063985 is a reply to message #1063886] Mon, 17 June 2013 06:57 Go to previous messageGo to next message
Mihael Schmidt is currently offline Mihael SchmidtFriend
Member
You could implement a BundleActivator to get access to a bundle context and get a reference to an OSGi service with it (or better use a ServiceTracker. Don't forget to declare the activator in the manifest file.
public class Activator implements BundleActivator {
	private ServiceTracker<IStateServiceClient, IStateServiceClient> stateServiceTracker;
	private static Activator instance;
	 * Returns the shared instance
	 * @return the shared instance
	public static Activator getInstance() {
		return instance;
	public void start(BundleContext context) throws Exception {
		instance = this;
		stateServiceTracker = new ServiceTracker<IStateServiceClient, IStateServiceClient>(context,
						IStateServiceClient.class.getName(), null);
		stateServiceTracker.open();
	public void stop(BundleContext context) throws Exception {
		stateServiceTracker.close();
		instance = null;
	public IStateServiceClient getStateService() {
		return stateServiceTracker.getService();
Manifest addition:
Bundle-Activator: my.package.Activator
In your web classes you can get access to the service like this:
Activator.getInstance().getStateService();
Remember to check for a null return value. If there is no active service registered in the OSGi environment atm then null will be returned.
Hope this helps
Mihael
Re: Using bundles with Wars [message #1064169 is a reply to message #1063985] Tue, 18 June 2013 04:34 Go to previous message
Violeta Georgieva is currently offline Violeta GeorgievaFriend
The BundleContext is available from the ServletContext attributes:
BundleContext ctxt = (BundleContext)
servletContext.getAttribute("osgi-bundlecontext");
OSGI Enterprise Spec chapter "128.6 Interacting with the OSGi Environment"
Violeta
Previous Topic:Virgo as a daemon
Next Topic:Missing part in understanding OSGI
Current Time: Tue Apr 16 14:02:52 GMT 2024
Powered by FUDForum. Page generated in 0.45559 seconds
