Home » Modeling » EMF » [CDO/Net4j] Sound check if TCPAcceptor could have been activated
Re: [CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1063753 is a reply to message #1063471] |
Fri, 14 June 2013 06:28 |
Am 13.06.2013 11:20, schrieb Kirsten M. Z.:
> Hi @all,
> For using CDO I create a simple server using the following (TCP) acceptor:
> IAcceptor acceptor = (IAcceptor) container.getElement(
> "org.eclipse.net4j.acceptors", "tcp",
> "0.0.0.0");
> // check if ok...
> if (LifecycleUtil.isActive(acceptor)) { /* ... */ } // <--- not meaningful, continue reading
> Of course, the whole process fails, if I try to start two servers. Then, I get the followign exception:
> ERROR [TCPSelector]: Address already in use: bind
> java.net.BindException: Address already in use: bind
Perhaps you should bind to different specific network addresses or different ports, e.g., 2036 and 2037.
> at sun.nio.ch.Net.bind(Native Method)
> at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:124)
> at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
> at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:52)
> at org.eclipse.net4j.internal.tcp.TCPAcceptor.handleRegistration(TCPAcceptor.java:136)
> at org.eclipse.net4j.internal.tcp.TCPSelector.executeRegistration(TCPSelector.java:389)
> at org.eclipse.net4j.internal.tcp.TCPSelector.access$0(TCPSelector.java:380)
> at org.eclipse.net4j.internal.tcp.TCPSelector$1.run(TCPSelector.java:71)
> at org.eclipse.net4j.internal.tcp.TCPSelector.processOperations(TCPSelector.java:376)
> at org.eclipse.net4j.internal.tcp.TCPSelector.run(TCPSelector.java:158)
> at java.lang.Thread.run(Thread.java:662)
> After this exception the acceptor will be deactivated (Net4j code)... asynchronously! Before this usually happens the
> acceptor is activated and seems to be fine (however, the server is obviously not running). This method is called on
> exception:
> protected void deactivateAsync()
> // Cancel the selection immediately
> cancelSelectionKey();
> // Do the rest of the deactivation asynchronously
> getConfig().getReceiveExecutor().execute(new Runnable()
> public void run()
> deactivate();
> My question: how can I process all this asynchronous stuff before I do other stuff assuming that the server start is
> fine?
There's LifecycleUtil.waitForActive(Object, long) and LifecycleUtil.waitForInactive(Object, long).
> Or: how can I determine that the server is actually running (ignoring the fact that the binding could collapse at any
> time)? Please see the comment in the first code.
The term "server" is a little vague, but I would define it as the "set of repositories and acceptors" in it. There's
LifecycleUtil.isActive(Object.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1121442 is a reply to message #1120214] |
Mon, 30 September 2013 16:24 |
Am 29.09.2013 11:57, schrieb Kirsten M. Z.:
> Hi again!
> Sorry for digging out this "old" Topic. Right now, I want to update my CDO Version. However, I cannot update "that
> easily", because I modified "my" current version. And the modification is because of the issue posted above (I am not
> using the async deactivation in case of the error, just using a very dirty *hack*).
> Then I also recognized that this discussion did not continue.
> What do you think? Isn't this an issue which should be solved?
Generally if there's a problem it should be solved. Please submit a bugzilla. My own priority to work on this is
probably not very high, as noone else has suffered from this problem during the last ten years and a workaround (check
if the port is available before activating the acceptor) seems trivial. Of course I'd appreciate if you can analyze the
problem and provide me with a patch to fix it. And of course I will try to answer your respective technical questions in
a timely manner ;-)
Cheers
/Eike
> If not, why? Did I miss a possiblity for a reliable check?
Cheers
/Eike
Re: [CDO/Net4j] Sound check if TCPAcceptor could have been activated [message #1121753 is a reply to message #1121442] |
Mon, 30 September 2013 23:41 |
Kirsten M. Z. Messages: 132 Registered: July 2010 |
> My own priority to work on this is probably not very high, as noone else has
Yes, for sure. Also using a delay is basically a workaround.
LifecycleUtil.waitForActive(acceptor, BASIC_TIME_OUT);
Thread.sleep(SOME_MS);
if (!LifecycleUtil.isActive(acceptor)) {
// ok, it failed, I got it...
However, I always have a bad feeling using something like that. After "waitForActive" I really expect that the acceptor is active, e.g., there is no "exception pending synchronously", which sets it inactive again. I think, this was your expectation (giving me the first answer) as well.
I will raise a bugzilla, and I will try to explain the problem. I cannot provide a real fix, because I think it is a general problem in asynchronous error handling, so maybe a architectural fix is needed? As a quick hack, just wait until it is performed, use a delay etc.
Current Time: Thu Apr 25 06:39:37 GMT 2024
Powered by FUDForum. Page generated in 0.03199 seconds
