Home » Eclipse Projects » BIRT » Problem with type "date"
Problem with type "date" [message #1063275] Wed, 12 June 2013 21:52 Go to next message
Fernando Aguada is currently offline Fernando AguadaFriend
Hi all,
I have a problem when running a birt report, throws me the following message:
"org.eclipse.birt.report.exception.ViewerValidationException: The parameter "RPHaFec" is invalid. The value "31/05/2013" is invalid with the type "date"."
How I can format a date type parameter in format "dd/mm/yyyy"?
Best Regards
Ferd
Re: Problem with type "date" [message #1064130 is a reply to message #1063275] Mon, 17 June 2013 18:25 Go to previous messageGo to next message
Kristopher Clark is currently offline Kristopher ClarkFriend
Is the date parameter being passed in the URL or is the user entering it? When you create the Date Time parameter in the designer you can click the change button next to the "format as" field and select a format from that list. If none of those work you can create a custom format with the format code box at the bottom.
Re: Problem with type "date" [message #1064165 is a reply to message #1064130] Mon, 17 June 2013 22:30 Go to previous message
index.php/fa/15297/0/Hello Kristopher,
The user is entering the date.Now I tested modify the parameter in the designer, as you explain, however does not work.
Attached a picture. Any other suggestions?
A detail, I call the report from php !
Thank you, very much for answering.
  • Attachment: report.png
    (Size: 150.33KB, Downloaded 1239 times)
Previous Topic:Filter Table by Expression: Last 7 Days
Next Topic:Bar Chart in Birt
Current Time: Mon Mar 01 04:46:32 GMT 2021
Powered by FUDForum. Page generated in 0.02181 seconds
