Re: Xtend Problem [message #1063688 is a reply to message #1063685] |
Thu, 13 June 2013 18:18 |
are you sure?
Caused by: java.lang.UnsupportedClassVersionError: org/xtext/example/mydsl/ui/MyDslExecutableExtensionFactory : Unsupported major.minor version 51.0
digg into the launch config (main tab)
maybe google can help since this does not seem to xtext specific
(close xtext projects, create a simple plugin project and run it to veryfy)
Twitter : @chrdietrich
Re: Xtend Problem [message #1290994 is a reply to message #1290969] |
Thu, 10 April 2014 16:12 |
Marc Schlegel Messages: 69 Registered: July 2009 |
Member |
Hi Christian,
You are right, the project settings were messed up. I setup my Eclipse with the IBM 1.6 JRE and I expected that it compiles with this one. But of course Eclipse ships with its own compiler and the projects were setup with 1.7. In my last post I just checked the compiler level for the workspace.
So we just disabled project-specific compiler level and everything is running as expcected.
Sorry for the confusion.
[Updated on: Thu, 10 April 2014 16:13] Report message to a moderator
FUDForum. Page generated in 0.04660 seconds
