Re: patching the source code [message #1063151 is a reply to message #1063054] |
Wed, 12 June 2013 13:42 |
Hi Arseniy,
If you've installed Epsilon on top of a clean Eclipse modelling distribution copy, you'll also need to install GMF manually (see the Epsilon downloads page). If this is not the case, could you please attach a copy of your project so that I can investigate?
Dimitris
Re: patching the source code [message #1063310 is a reply to message #1063188] |
Wed, 12 June 2013 23:32 |
Hi Arsenyi,
The previous version of Eugenia did not provide any dedicated support for imported EPackages so I'm afraid this worked accidentally. In the latest version one would need to add the following annotation to point Eugenia at the imported genmodel.
@emf.gen.usedGenPackage(name="sub", genModel="platform:/resource/drilldown/sub/sub.genmodel")
package core;
This works fine until the .gmfmap -> .gmfgen step of the workflow however at that point calling the gmfmap->gmfgen built-in transformation of GMF fails (without an exception) while invoking it through the UI (right-click .gmfmap -> Create Generator Model) seems to be working fine. Clearly, I'll need to investigate more but I suspect that until then, you're better off with the latest stable version of Epsilon. Apologies for any inconvenience this may cause.
Dimitris
FUDForum. Page generated in 0.03496 seconds
