Home » Eclipse Projects » Remote Application Platform (RAP) » ControlContribution in a view's menu bar(org.eclipse.jface.action.ControlContribution in a view's ToolBar)
ControlContribution in a view's menu bar [message #1062716] |
Mon, 10 June 2013 13:26 |
Julia Kurde Messages: 91 Registered: November 2011 Location: Berlin, Germany |
Member |
I have a strange behavior of a ControlContribution in the ToolBar of a View: The Control (e.g. a Spinner) does not keep its focus.
The attached figure shows the example "RAP Application with a View" generated by the New Plug-in Project wizard. I just modified the Perspective so that the view has a Title and in the method createPartControl(Composite) of the View I add a Label and the ControlContribution in the ToolBar:
public void createPartControl(Composite parent) {
int style = SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL;
viewer = new TableViewer(parent, style);
viewer.setContentProvider(new ViewContentProvider());
viewer.setLabelProvider(new ViewLabelProvider());
viewer.setInput(getViewSite());
label = new Label(parent, SWT.BORDER);
label.setText("label");
IToolBarManager manager = getViewSite().getActionBars().getToolBarManager();
manager.add(new MyControlItem(this));
MyControlItem looks like this:
public class MyControlItem extends ControlContribution {
View view;
public MyControlItem (View view) {
super("id");
this.view = view;
protected Control createControl(Composite parent) {
final Spinner spinner = new Spinner(parent, SWT.BORDER);
spinner.setMinimum( 25);
spinner.setMaximum(400);
spinner.setIncrement(25);
spinner.setPageIncrement(100);
spinner.setSelection(100);
spinner.addListener(SWT.Traverse, new Listener() {
public void handleEvent(Event event) {
switch (event.detail) {
case SWT.TRAVERSE_RETURN:
view.setLabelText(String.valueOf(spinner.getSelection()));
spinner.addListener(SWT.FocusOut, new Listener() {
return spinner;
What it SHOULD do: Update the label in the view on SWT.FocusOut or on SWT.Traverse with event.detail == SWT.TRAVERSE_RETURN.
What it ACTUALLY does: Update the label every time the value of the spinner is changed.
The reason for that is that the spinner does not keep it's focus, so a focus out event occurs.
In my real application it is not a label that should be updated but an image. To minimize the traffic it should really only be updated on focus out.
In an RCP application the label/image is updated correctly.
Is it possible get the correct behavior also in the RAP?
Julia
Re: ControlContribution in a view's menu bar [message #1062749 is a reply to message #1062716] |
Mon, 10 June 2013 15:26 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Julia,
if the behavior duffers from RCP it's probably a bug. Please file a
bugzilla and we will investigate the issue.
Ivan
On 6/10/2013 4:26 PM, Julia Kurde wrote:
> View view;
> super("id");
> this.view = view;
> @Override
> return spinner;
> Regards,
> Julia
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: ControlContribution in a view's menu bar [message #1062756 is a reply to message #1062716] |
Mon, 10 June 2013 15:49 |
Julia,
BTW I've tested your snippet with RAP 2.1 RC3 and it's working as you
expected. Which RAP version are you using? Which browser?
Best,
Ivan
> View view;
> super("id");
> this.view = view;
> @Override
> return spinner;
> Regards,
> Julia
Ivan Furnadjiev
Re: ControlContribution in a view's menu bar [message #1063018 is a reply to message #1063001] |
Tue, 11 June 2013 19:19 |
Julia,
the extensionbundle has been removed in Equinox, it is not really
needed. The WAR products tool did not handle that correctly, but this
problem is fixed in Kepler [1]. If that was the only problem, it should
not keep you from upgrading.
As far as I understand it, the old plugin.xml should still work with RAP
2.1 / Kepler, but support will be removed after Kepler [2]. However,
changing your bundles should be simple: remove the <requires> elements
from the plugin.xml, and add those dependencies using the manifest editor.
Ralf
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=398780
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=407312
Ralf Sternberg
Re: ControlContribution in a view's menu bar [message #1063191 is a reply to message #1063018] |
Wed, 12 June 2013 15:11 |
Member |
Thanks, Ralf!
I could update these old style plugins . One has to increase the version number, too, else the whole workspace gets messed up!
I also use now Kepler with RAP 2.1 and the war file is generated without problem (org.eclipse.equinox.servletbridge.extensionbundle is not included).
But again I get this NoSuchMethodError when trying to start the application on tomcat6:
HTTP Status 500 - Servlet execution threw an exception
type Exception report
message Servlet execution threw an exception
description The server encountered an internal error that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
root cause
java.lang.NoSuchMethodError: javax.servlet.http.Cookie.setHttpOnly(Z)V
org.eclipse.rap.rwt.internal.service.SettingStoreManager.getStoreId(SettingStoreManager.java:91)
org.eclipse.rap.rwt.internal.service.SettingStoreManager.getStore(SettingStoreManager.java:34)
org.eclipse.rap.rwt.RWT.getSettingStore(RWT.java:484)
org.eclipse.rap.ui.internal.preferences.SessionPreferencesNode.internalGet(SessionPreferencesNode.java:487)
org.eclipse.rap.ui.internal.preferences.SessionPreferencesNode.get(SessionPreferencesNode.java:196)
org.eclipse.core.internal.preferences.PreferencesService.get(PreferencesService.java:465)
org.eclipse.ui.preferences.ScopedPreferenceStoreCore.internalGet(ScopedPreferenceStoreCore.java:457)
org.eclipse.ui.preferences.ScopedPreferenceStoreCore.getBoolean(ScopedPreferenceStoreCore.java:370)
org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:447)
org.eclipse.ui.internal.UISynchronizer.<init>(UISynchronizer.java:88)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
eub.rapjlzhview.Application.start(Application.java:18)
org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
java.lang.Thread.run(Unknown Source)
org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.37 logs.
All plugins are in the status active except the org.eclipse.equinox.servletbridge.extensionbundle:
osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20130529-1710
Fragments=23
1 ACTIVE com.ibm.icu.base_50.1.1.v201304230130
2 ACTIVE eub.jlzhinternal_1.0.0
3 ACTIVE eub.jlzhtools_1.0.0
4 ACTIVE eub.lib_2.0.0
5 ACTIVE eub.lzhview_2.0.0
6 ACTIVE eub.rapjlzhview_1.0.0.201306121638
7 ACTIVE eub.tableeditor_3.0.0
8 ACTIVE javax.xml_1.3.4.v201005080400
9 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
10 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
11 ACTIVE org.eclipse.core.commands_3.6.100.v20130515-1857
12 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130326-1255
13 ACTIVE org.eclipse.core.databinding_1.4.1.v20130515-1857
14 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130515-1857
15 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130515-1857
16 ACTIVE org.eclipse.core.expressions_3.4.500.v20130515-1343
17 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
18 ACTIVE org.eclipse.core.runtime_3.9.0.v20130326-1255
19 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
20 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
21 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
22 ACTIVE org.eclipse.equinox.http.registry_1.1.300.v20130402-1529
23 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.3.0
Master=0
24 ACTIVE org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354
25 ACTIVE org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-144
2
26 ACTIVE org.eclipse.equinox.preferences_3.5.100.v20130422-1538
27 ACTIVE org.eclipse.equinox.registry_3.5.300.v20130327-1442
28 ACTIVE org.eclipse.help_3.6.0.v20130326-1254
29 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
30 ACTIVE org.eclipse.rap.design.example_2.1.0.20130524-0811
31 ACTIVE org.eclipse.rap.jface_2.1.0.20130506-1748
32 ACTIVE org.eclipse.rap.jface.databinding_2.1.0.20130506-1748
33 ACTIVE org.eclipse.rap.rwt_2.1.0.20130527-1011
34 ACTIVE org.eclipse.rap.rwt.osgi_2.1.0.20130506-1748
35 ACTIVE org.eclipse.rap.ui_2.1.0.20130528-1219
36 ACTIVE org.eclipse.rap.ui.workbench_2.1.0.20130506-1748
osgi>
NoSuchMethodError sounds like incompatible java versions, but all Plugins are compiled with jre6, which is also installed on the server (which is localhost).
Any idea, what could be the problem?
Besides that, the spinner in my toolbar still does not behave correctly, unfortunately...
Re: ControlContribution in a view's menu bar [message #1063196 is a reply to message #1063191] |
Wed, 12 June 2013 15:17 |
Hi Julia,
we reverted the fix for bug 408656 last night. See:
408656: HttpOnly flag for settingStore cookie
https://bugs.eclipse.org/bugs/show_bug.cgi?id=408656
RAP 2.1RC4 should run again on servlet 2.5 without a problem.
Best,
Ivan
On 6/12/2013 6:11 PM, Julia Kurde wrote:
> Thanks, Ralf!
> I could update these old style plugins :). One has to increase the
> not included).
> exception
> root cause
> Tomcat/6.0.37 logs.
> osgi> ss
> id State Bundle
> Fragments=23
> 14 ACTIVE
> 15 ACTIVE
> Master=0
> 25 ACTIVE
> 2
> osgi>
Ivan Furnadjiev
Current Time: Thu Apr 25 01:55:13 GMT 2024
Powered by FUDForum. Page generated in 0.04050 seconds
