Home » Eclipse Projects » BIRT » birt chart not show(org.eclipse.emf.ecore.resource.Resource$IOWrappedException)
birt chart not show [message #1062567] Sun, 09 June 2013 03:39 Go to next message
sun lingfeng is currently offline sun lingfengFriend
I work just like this http://www.eclipse.org/forums/index.php/m/519023/ in birt 4.2.2,I also face the same error.Chart can not show properly.The other report can show correctly.I searched found somebody said it is xerces problem.But I can not solve it.Who can help me?Thanks.
Re: birt chart not show [message #1062757 is a reply to message #1062567] Mon, 10 June 2013 15:50 Go to previous messageGo to next message
Kristopher Clark is currently offline Kristopher ClarkFriend
Have you checked your config file as suggested by this bug to see what order the BIRT jars are being loaded?
Re: birt chart not show [message #1063535 is a reply to message #1062757] Thu, 13 June 2013 11:45 Go to previous message
I don't know how to config start sequence,can you explain detail?thanks
Previous Topic:showing chart with Birt RE API
Next Topic:Problem building BIRT Jars
Current Time: Fri Jan 24 01:20:40 GMT 2020
Powered by FUDForum. Page generated in 0.04062 seconds
