Re: BIRT Server with Charts [message #1062657 is a reply to message #1062596] |
Mon, 10 June 2013 09:41 |
donino donino Messages: 183 Registered: July 2011 |
Hi Gael,
This org.eclipse.birt.chart.device.svg.SVGRendererImpl class seems to be in the global "org.eclipse.birt.runtime" jar, i dont think it is really missing if you use a v3.7+ birt runtime. I have already heard about this issue with Debian and SVG charts. I can't give a solution but at least a workaround is to set up a PNG format instead of SVG in the chart properties of your report design.
[Updated on: Mon, 10 June 2013 09:44] Report message to a moderator
Re: BIRT Server with Charts [message #1065817 is a reply to message #1065813] |
Thu, 27 June 2013 15:17 |
I had a coworker of mine try this with his setup. He had debian with openjdk6, birt 4.2.2, and tomcat 7 and had no issues. Can you try downloading BIRT again to make sure you didn't get a bad copy?
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.03389 seconds
