unhandled event loop in juno and kepler [message #1062344] |
Fri, 07 June 2013 10:08 |
Hi recently i have shifted from indigo to juno. With juno there is a problem. For every 2 min it says "Unhandled Event Loop Exception" and gets shutdown. So I got irritated and downloaded "Kepler" thinking that this might have solution. But with this also it is the same problem. Is there any way to get out of this or I have to get back to "Indigo" again.
How to resolve this?
Thanks and Regards,
Muralidhar Yaragalla.
http://yaragalla.blogspot.in
Re: unhandled event loop in juno and kepler [message #1062486 is a reply to message #1062347] |
Sat, 08 June 2013 04:18 |
The message that gets displayed is : Unhandled event loop exception
The following is the exception stack trace:-
org.eclipse.swt.SWTError: Item not added
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.ToolBar.createItem(ToolBar.java:392)
at org.eclipse.swt.widgets.ToolItem.<init>(ToolItem.java:128)
at org.eclipse.jface.action.Separator.fill(Separator.java:67)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.ui.internal.EditorActionBars.setVisible(EditorActionBars.java:478)
at org.eclipse.ui.internal.EditorActionBars.setActive(EditorActionBars.java:375)
at org.eclipse.ui.internal.EditorActionBars.activate(EditorActionBars.java:125)
at org.eclipse.ui.internal.PartSite.activateActionBars(PartSite.java:594)
at org.eclipse.ui.internal.EditorSite.activateActionBars(EditorSite.java:74)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:279)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:194)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:183)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:181)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:595)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:539)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:104)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:59)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1453)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2334)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4655)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4990)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2544)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4706)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3141)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
The session data is as below:-
eclipse.buildId=4.3.0.I20130526-2000
java.version=1.6.0_31
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Thanks and Regards,
Re: unhandled event loop in juno and kepler [message #1062811 is a reply to message #1062685] |
Mon, 10 June 2013 20:19 |
See i don't know who you are. Why should i threaten you. Forum is a public place to discuss anything we like. I am a die hard fan of eclipse. From the very beginning of my career i am with eclipse. But this problem really hurts. for every 5 min my IDE shuts down. Really annoying and irritating. This bug is there in juno but still exist in later release as well (kepler). With this there are only 2 options eighter get back to indigo or leave eclipse. Indigo become too old now so if we can fix and move that's fine or move out of the IDE. There is no choice left. Any way i don't have intentions to threaten any one and there are no people that gets scared. The world is not filled with cowards. so don't worry too much.
IF any one found any work around please post the solution. Thanks in advance.
Thanks and Regards,
Re: unhandled event loop in juno and kepler [message #1063000 is a reply to message #1062819] |
Tue, 11 June 2013 17:02 |
The OS is "windows 7". Java version is 1.6. No any extra plugins. First i have installed juno which started this. After that i have removed and installed kepler. Once installation is done i have added few plugins like windowbuilder and few other UML pugins and also updated the existing software. The problem still exist. so i have deleted kepler and just installed the default kepler which i downloaded from eclipse site and also i have changed the workspace but still the problem exist.
Thanks and Regards,
FUDForum. Page generated in 0.04261 seconds
