Home » Archived » BIRT » how to get value for parameter
how to get value for parameter [message #1062287] Fri, 07 June 2013 00:26 Go to next message
BIRT my question is when i select parameter in list box it have to compare a value in chart it have to produce a result...
for example if i am having a one list box i.e select month: jan 2013,feb 2013,mar 2013 and then another list box Period:Last month,Last year
when i select a Jan 2013 from one list box and then i wil select Last Month or Last year in another list box so result will be Jan 2013 total value and DEC 2012 total value for Last Month likewise then i will select Last Year Jan 2013 total value and Jan 2012 total value have to display....
i have attached a sample report and image for u r reference..
thank's in advance
  • Attachment: re.png
    (Size: 14.10KB, Downloaded 200 times)
  • Attachment: lastmonth.rptdesign
    (Size: 49.17KB, Downloaded 338 times)
[Updated on: Fri, 07 June 2013 00:31] by Moderator
Re: how to get value for parameter [message #1062556 is a reply to message #1062287] Sat, 08 June 2013 20:37 Go to previous messageGo to next message
There are BirtDateTime functions available in the expression builder and script methods that will allow you to find the proper month based on the two parameter values. Then, you'd just need to adjust your query to limit your data.
Re: how to get value for parameter [message #1062613 is a reply to message #1062556] Mon, 10 June 2013 00:57 Go to previous messageGo to next message
thank u very much for reply i have tried this way ...but i cant able to get appropriate value of parameter
so can u able to produce a sample db example for this...its helpful for me ...
thank in advance...
Re: how to get value for parameter [message #1062837 is a reply to message #1062613] Tue, 11 June 2013 00:19 Go to previous messageGo to next message
I posted a sample in your thread over on BIRT Exchange:
BIRT Exchange Forum - Comparison in Parameter
Re: how to get value for parameter [message #1063611 is a reply to message #1062837] Thu, 13 June 2013 09:55 Go to previous messageGo to next message
thank u for wonderful post....................
Re: how to get value for parameter [message #1064388 is a reply to message #1063611] Wed, 19 June 2013 00:56 Go to previous message
You're very welcome!
Previous Topic:empty space between border top and text
Next Topic:Parameterized Query - Problem
Current Time: Sun Apr 20 01:03:44 EDT 2025
Powered by FUDForum. Page generated in 0.03900 seconds
