Home » Eclipse Projects » Remote Application Platform (RAP) » E4/RAP Integration
E4/RAP Integration [message #1061993] Wed, 05 June 2013 10:01 Go to next message
Vijay RajFriend
Hello everyone,
Can anybody please point me to the git path for the below experimental e4 RAP integration.
Or any other source.
http://wiki.eclipse.org/E4/RAP_Integration/Experimental
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Wed, 05 June 2013 11:10]
Report message to a moderator
Re: E4/RAP Integration/Experimental git path? [message #1062177 is a reply to message #1061993] Thu, 06 June 2013 11:58 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
This example is years old, the code is probably buried in the Eclipse
CVS that has been shut down meanwhile. There was another experiment to
run RAP applications on E4 [1], with some experimental source code on
github.
However, don't expect anything ready to use yet. There are still some
bugs in E4 that prevent running multi-user applications like RAP, see
[2]. These bugs are currently blocking our efforts.
Ralf
[1] http://eclipsesource.com/blogs/2012/07/16/eclipse-4-applications-on-rap/
[2] 392977: Support multi-user applications on a server
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392977
Ralf Sternberg
Twitter: @EclipseRAP
Re: E4/RAP Integration/Experimental git path? [message #1062185 is a reply to message #1062177] Thu, 06 June 2013 12:22 Go to previous messageGo to next message
Vijay RajFriend
Thanks Ralf for the answer,
Yes i know this is pretty old,the [1] link also i saw, and yes i am aware of the multi user bug also.
I just need to do a POC on E4 rap, just to prove that yep it is possible and yes there is going to be a stable release in the
future, which can then be used to port current to be built E4 application.
The issue is the code in those posts is now invalid for even 4.2 eclipse. I imported the code and there is lot of compilation errors in them.
Hence i was searching for a fresh code which i can use. Or just the steps, so that i can do the experiment Smile.
EDIT:Thanks i got the steps from the Link[1].
Is there a planned release of E4 rap or not yet planned?
Vijay
[Updated on: Fri, 07 June 2013 05:38]
Re: E4/RAP Integration/Experimental git path? [message #1062618 is a reply to message #1062185] Mon, 10 June 2013 05:42 Go to previous message
Vijay RajFriend
Ok i got your old code and Modified the 4.3 plugins as you suggested.
I had to also do some more changes in the example code(api and package level changes).
Anyway its running now with some exceptions in background.
I agree that lot of work is still pending and its not complete for further development.
I am attaching the same with this post for further reference.
Thank you very much Rolf.
4.3 E4 RAP.zip
Vijay
Previous Topic:Calling RAP Code From The Outside
Next Topic:[ANN] RAP 2.1 RC3 is available
Current Time: Fri Dec 03 02:18:59 GMT 2021
Powered by FUDForum. Page generated in 0.01990 seconds
