Home » Eclipse Projects » BIRT » change bars / track changes
change bars / track changes [message #1061975] Wed, 05 June 2013 08:22 Go to next message
stacey hopkins is currently offline stacey hopkinsFriend
Does anyone have any experience in using BIRT to provide differences between one version of a document and another. ?
I am for example talking about change bars in the margin which shows which parts of the document has changed since the previous version.
It does not necessarily have to match this implementation but something that can indicate to the user that this part of the document has changed since the previous release.
Thanks in advance.
Re: change bars / track changes [message #1062760 is a reply to message #1061975] Mon, 10 June 2013 15:58 Go to previous message
Kristopher Clark is currently offline Kristopher ClarkFriend
What format are you rendering the reports in? If it's a PDF there might be some software that you can use to compare the two documents and return the differences.
Previous Topic:Dynamic Date Parameters in BIRT 3.7.1
Next Topic:Fill pdf page with table / vertical lines + transport totals
Current Time: Mon Feb 17 06:17:42 GMT 2020
Powered by FUDForum. Page generated in 0.03275 seconds
