Home » Eclipse Projects » Riena » Hotkeys for subapplications
Hotkeys for subapplications [message #1061623] Mon, 03 June 2013 10:51 Go to next message
Joe Sobeos is currently offline Joe SobeosFriend
is there an easy way to define hotkeys for subapplication?
Can somebody give me an example?
I read about key bindings, but I don't know how to get the command of a subapplication.
Thanks in advance,
Joe
Re: Hotkeys for subapplications [message #1064059 is a reply to message #1061623] Mon, 17 June 2013 13:09 Go to previous messageGo to next message
Thorsten Schenkel is currently offline Thorsten SchenkelFriend
Hi Joe,
I don't know exactly what you want to do.
1. Do you need hotkeys to switch from one sub-application to another?
Riena has already define hotkeys to switch form one sub-application to next (ctrl+page up) or to previous (ctrl+page down) sub-application.
Also you can use mnemonics to active one sub-application. Add the character "&" inside the label of the sub-application.
Example:
   ISubApplicationNode subApplication = new SubApplicationNode(new NavigationNodeId(
				"org.eclipse.riena.example.navigation.subapplication"), "Na&vigation");
2. Do you need hotkeys that only work in the context of a special sub-application?
Riena doesn't support this. Because not special context is activated for sub-applications.
If you need this, please open a bug.
Thorsten
Re: Hotkeys for subapplications [message #1064201 is a reply to message #1064059] Tue, 18 June 2013 08:46 Go to previous message
Hi Thorsten,
thanks a lot for your response.
Exactly what I was looking for.
Beste regards,
Joe
Previous Topic:Riena 5.0 on RAP 2.0, e4, e3
Next Topic:Riena Quo Vadis?
Current Time: Mon Jul 13 02:48:11 GMT 2020
Powered by FUDForum. Page generated in 0.01679 seconds
