Home » General (non-technical) » Project Proposals » Concierge
Concierge [message #1061541] Sun, 02 June 2013 16:12 Go to next message
Wayne Beaton is currently offline Wayne BeatonFriend
Concierge is a small-footprint implementation of the OSGi Core Specifications R3 standard optimized for mobile and embedded devices.
For more information, please see:
http://www.eclipse.org/proposals/rt.concierge/
Re: Concierge [message #1061635 is a reply to message #1061541] Mon, 03 June 2013 11:30 Go to previous messageGo to next message
Rick Bullotta is currently offline Rick BullottaFriend
A couple of things were not entirely apparent from the proposal:
- Which JVM type(s) are targeted? (ME, SE, SE embedded, etc.)
- Why the goal of running on version 1.4 JVMs? Seems a major compromise and a big security risk since even 1.6 VM's are now close to being EOL'ed
Thanks in advance for your response.
Rick Bullotta
ThingWorx
Re: Concierge [message #1061748 is a reply to message #1061635] Mon, 03 June 2013 18:27 Go to previous messageGo to next message
Jan S. Rellermeyer is currently offline Jan S. RellermeyerFriend
Thanks for your input.
The goal is not to run on Java 1.4 and nothing else. The goal is to run on 1.4 and higher. I think this is important since some embedded devices still have VMs with CDC 1.1 profile. This might change when Java 8 profiles become reality.
People concerned about VM security updates can indeed run Concierge on a newer VM without any problems.
Technically, this means that Concierge will only rely on classes available from a 1.4 classpath. It will use generics (the OSGi R5 API uses generics) but in addition to a release targeted for VMs >=1.5 we plan to also generate a binary with the jsr14 option that is able to run on a 1.4 SE VM or on CDC 1.1.
Re: Concierge [message #1064329 is a reply to message #1061748] Tue, 18 June 2013 18:17 Go to previous messageGo to next message
Werner Keil is currently offline Werner KeilFriend
Given the M2M and Java Embedded relevance of Concierge, could you please
list me as Interested party similar to e.g. the Ponte proposal:
- Werner Keil, Eclipse UOMo Project lead
Werner
Re: Concierge [message #1065229 is a reply to message #1064329] Mon, 24 June 2013 22:09 Go to previous message
I am happy to add you to the interested parties, Werner.
Give me another day to work on a proposal update.
Jan.
Previous Topic:New Proposal: Vert.x
Next Topic:ArCon project creation review scheduled
Current Time: Sat May 30 22:41:42 GMT 2020
Powered by FUDForum. Page generated in 0.02100 seconds
