Home » Modeling » ATL » new instance in an ATL transformation
new instance in an ATL transformation [message #1061242] |
Thu, 30 May 2013 17:29 |
achraf lyazidi Messages: 12 Registered: May 2013 |
Hello, i have a bpmn2petrinet.atl file like the following
module bpmn2PetriNet;
create OUT : PetriNet from IN : bpmn2; --bpmn
rule PetriNet {
from
g : bpmn2!Process
to
p : PetriNet!PetriNet
location <- g.location,
name <- g.name,
elements <- g.elements,
arcs <- g.flows
--event to place --
rule Place {
from
g : bpmn2!Event
to
p : PetriNet!Place
name <- g.name,
net <- g.process,
incomingArc <- g.incomingConnections,
outgoingArc <- g.outgoingConnections
-- task to transition
rule Transition {
from
g : bpmn2!Task
to
p : PetriNet!Transition
name <- g.name,
net <- g.process,
-- gateway to transition
rule Transition2 {
from
g : bpmn2!Gateway
to
name <- g.name,
net <- g.process,
rule PlaceToTransition {
from
g : bpmn2!EventtoTask
to
p : PetriNet!PlaceToTransition
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- g."to"
rule TransitionToPlace {
from
g : bpmn2!TasktoEvent -- TasketoGatway -- GatewaytoTask
to
p : PetriNet!TransitionToPlace
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- g."to"
rule TransitionToTransition {
from
g : bpmn2!TaskGatewaytoTaskGateway
to
p : PetriNet!TransitiontoPlace
name <- g.name,
net <- g.process,
"from" <- g."from"--,
--"to" <- newplace
q : PetriNet!PlaceToTransition
name <- g.name + '2',
net <- g.process,
--"from" <- newplace,
"to" <- g."to"
Teh problem that i have is in the rule TransitionToTransition , because in the "to" <- newplace and the "from" <- newplace , i want that place to be a new created place.
For example in BPMN when 2 task A following by B, in the corresponding Petri Net, i'll have 2 transition A following directly by B, but it's a mistake because between every transition we should have a place in a Petri Net, so i want to add a new place between 2 transitions but i don't know how i can program it in the ATL file.
Thanks.
Re: new instance in an ATL transformation [message #1061610 is a reply to message #1061242] |
Mon, 03 June 2013 09:26 |
Hugo Bruneliere Messages: 674 Registered: July 2009 |
You could do something like:
from
to
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- newplace
net <- g.process,
"from" <- newplace,
"to" <- g."to"
newplace : PetriNet!Place (
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
Re: new instance in an ATL transformation [message #1061725 is a reply to message #1061610] |
Mon, 03 June 2013 15:16 |
Thank you i did what you told me , but when i launch my ATL transformation i got the followin error :
Quote:org.eclipse.m2m.atl.engine.emfvm.VMException: Cannot find class TransitiontoPlace in reference model PetriNet
I think because i call the class TransitiontoPlace two times, one time alone, and one time into the TransitiontoTransition rule, but i'm not sure
create OUT : PetriNet from IN : bpmn3; --bpmn
rule PetriNet {
from
g : bpmn3!Process
to
name <- g.name,
arcs <- g.flows
--event to place --
rule Place {
from
g : bpmn3!Event
to
p : PetriNet!Place
name <- g.name,
net <- g.process,
--task to transition
rule Transition {
from
g : bpmn3!Task
to
name <- g.name,
net <- g.process,
from
g : bpmn3!EventtoTask
to
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- g."to"
from
g : bpmn3!TasktoEvent
to
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- g."to"
from
g : bpmn3!TasktoTask ,
to
name <- g.name,
net <- g.process,
"from" <- g."from",
"to" <- newplace
t : PetriNet!PlaceToTransition
net <- g.process,
"from" <- newplace,
"to" <- g."to"
name <- g.name + 'place',
--net <- g.process,
incomingArc <- p.outgoingConnections,
outgoingArc <- t.incomingConnections
Current Time: Thu Apr 25 08:26:37 GMT 2024
Powered by FUDForum. Page generated in 0.03777 seconds
