Home » Modeling » GMF (Graphical Modeling Framework) » GMF multi views
GMF multi views [message #1061192] Thu, 30 May 2013 13:19 Go to next message
abdelkader didouh is currently offline abdelkader didouhFriend
Hello
I am new to this forum, so i am sorry in advance if my issue has been already addressed before.
I am trying to build a tool for security modelling using GMF. and one of the requirement is to create different views with different palettes. can some one help me or tell me where i should ask if this is not the right place.
Thank you
Re: GMF multi views [message #1061357 is a reply to message #1061192] Fri, 31 May 2013 10:19 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
you can simply try to define different gmf editors on one meta-model using GMF. You could also take a look at the topic of Orthographic Software Modeling and tools enabling this. Tools for such a case would be Atom3 and Naomi.
Ralph
Re: GMF multi views [message #1061424 is a reply to message #1061357] Fri, 31 May 2013 14:43 Go to previous messageGo to next message
hi Ralph Gerbig,
thank you for your answer.
How can i define different gmf editors ? am sorry GMF is really new to me
Abdelkader,
Re: GMF multi views [message #1061689 is a reply to message #1061424] Mon, 03 June 2013 13:51 Go to previous messageGo to next message
follow this tutorial to learn how to define a GMF editor http://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_1. You can also read this book (http://www.eclipse.org/resources/resource.php?id=493).
Ralph
Re: GMF multi views [message #1066158 is a reply to message #1061689] Mon, 01 July 2013 10:02 Go to previous messageGo to next message
HI,
I know how to create one editor, bit how can i create many editors using one meta-model in the same tool. my objective is to get one tool with different views, and each view with different palettes.
Thank you for your precious help.
Re: GMF multi views [message #1066380 is a reply to message #1066158] Tue, 02 July 2013 11:47 Go to previous message
just define multiple gmf editors on the same model. You could then use something like a dimension explorer to invoke the right editor on your model. We have an approach for view based modelling using a single underltying model and create views through transformations. This could be of interest for you:
http://code.google.com/a/eclipselabs.org/p/naomi/
Ralph
Previous Topic:Gradient feature of Node
Next Topic:Defining a maximun size for a node
Current Time: Fri Apr 16 00:49:37 GMT 2021
Powered by FUDForum. Page generated in 0.01955 seconds
