Re: white screen when waiting for response [message #1065818 is a reply to message #1065699] |
Thu, 27 June 2013 15:19 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi André,
please look at your theme about the following CSS:
SystemMessage-DisplayOverlay {
background-color: rgba( 128, 128, 128, 0.3 );
background-image: none;
Do you have it? If not add it to your theme and try again.
HTH,
Ivan
On 6/27/2013 5:27 PM, André Kemter wrote:
> Hey,
> I have the same problem than you, have you found any solution?
> thx André
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: white screen when waiting for response [message #1066145 is a reply to message #1066133] |
Mon, 01 July 2013 09:27 |
André,
when a response from the server is delayed, the screen is blocked by an
overlay to prevent further interaction. The look of this overlay can be
changed in the theme, as Ivan explained.
However, you shouldn't usually see this overlay often, unless you have
an unusually long network latency. If you do anyway, you should have a
look at the response times.
Long response times can be caused by time-consuming operations running
directly in the UI thread. Could this be the case in your application?
Ralf
Ralf Sternberg
FUDForum. Page generated in 0.03610 seconds
