Home » Eclipse Projects » Remote Application Platform (RAP) » How to Resize FillLayout in 2.0?(Converting 1.4 app to 2.0. Browser resize not working.)
How to Resize FillLayout in 2.0? [message #1060166] Thu, 23 May 2013 11:39 Go to next message
Erwin Hogeweg is currently offline Erwin HogewegFriend
Member
While converting a 1.4 app to 2.0 I noticed that the browser resize doesn't work anymore on a FillLayout. I checked the 1.5 and the 2.0 migration guides, but didn't see anything specific about this.
Is there a solution for that in 2.0, or do I have to wait for the display resize event in 2.1?
Kind Regards,
Erwin
Re: How to Resize FillLayout in 2.0? [message #1060189 is a reply to message #1060166] Thu, 23 May 2013 12:51 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Erwin,
just did a small test with RAP 2.0 - maximized Shell with FillLayout and
child Composite. Resizing of the browser does a resize of the child
Composite. I don't see any problem. Could you provide some lines of code
to demonstrate the issue?
Best,
Ivan
On 5/23/2013 2:39 PM, Erwin Hogeweg wrote:
> Kind Regards,
> Erwin
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: How to Resize FillLayout in 2.0? [message #1060217 is a reply to message #1060189] Thu, 23 May 2013 14:46 Go to previous messageGo to next message
Member
Ivan,
Thanks for the reply. It is a bit difficult to post an complete example here because there are quite a few classes involved.
When looking for code to show here I noticed that it is likely not related to the FillLayout, but to the FormLayout. The code below, which is a shameless copy of the sample code, creates a header, a sidebar and a mainArea.
The form shows up correctly, but it won't resize.
Tested with FF-20.0 and Safari, both on Mac.
Any help is highly appreciated.
Kind Regards,
Erwin
    private void createContent(Shell shell) {
        FormLayout layout = new FormLayout();
        shell.setLayout(layout);
        Control header = createHeader(shell);
        header.setLayoutData(createHeaderFormData());
        sidebar = createSidebar(shell, someData);
        sidebar.setLayoutData(createSidebarFormData());
        mainArea = createMainArea(shell);
        mainArea.setLayoutData(createMainAreaFormData());
        statusArea = createStatusArea(shell);
        statusArea.setLayoutData(createStatusAreaFormData());
   private FormData createMainAreaFormData() {
        FormData data = new FormData();
        data.top = new FormAttachment(0, HEADER_HEIGHT + 20);
        data.left = new FormAttachment(0, 230 + 10);
        data.right = new FormAttachment(100, -20);
        data.bottom = new FormAttachment(100, -30);
        return data;
Re: How to Resize FillLayout in 2.0? [message #1060222 is a reply to message #1060217] Thu, 23 May 2013 15:11 Go to previous messageGo to next message
Hi Erwin,
the following code works for me in both RAP 2.0 and 2.1RC1:
public class SimpleEntryPoint extends AbstractEntryPoint {
public void createContents( Composite parent ) {
parent.setLayout( new FormLayout() );
Composite composite = new Composite( parent, SWT.NONE );
composite.setBackground( parent.getDisplay().getSystemColor(
SWT.COLOR_DARK_CYAN ) );
composite.setLayoutData( createMainAreaFormData() );
data.top = new FormAttachment( 0, 50 + 20 );
data.left = new FormAttachment( 0, 230 + 10 );
data.right = new FormAttachment( 100, -20 );
data.bottom = new FormAttachment( 100, -30 );
return data;
Best,
Ivan
On 5/23/2013 5:46 PM, Erwin Hogeweg wrote:
> Ivan,
> Kind Regards,
> Erwin
> return data;
Ivan Furnadjiev
Re: How to Resize FillLayout in 2.0? [message #1060363 is a reply to message #1060217] Fri, 24 May 2013 09:55 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Erwin,
if you forget the main loop in a snippet running in SWT mode, you get
exactly this behavior. Unlikely that this is the problem in your case,
it's just something to double-check...
Ralf
Ralf Sternberg
Re: How to Resize FillLayout in 2.0? [message #1060472 is a reply to message #1060222] Sat, 25 May 2013 02:47 Go to previous message
Member
Ivan,
Your example works for me as well...
In my EntryPoint class I implemented EntryPoint i.o. extending AbstractEntryPoint.
Haven't completely figured it out yet, but I am sure it has something to do with that. At least now I have something to build on.
Thanks again for your help.
Kind Regards,
Erwin
Previous Topic:Infocenter as a WAR
Next Topic:MenuItems have a wrong order in Menu
Current Time: Mon Dec 06 21:13:31 GMT 2021
Powered by FUDForum. Page generated in 0.02803 seconds
