Home » Archived » Hudson » Hudson 3.0.1 : I cannot delete a Job(Hudson bug)
Hudson 3.0.1 : I cannot delete a Job [message #1060149] Thu, 23 May 2013 10:33 Go to next message
cyril jourda is currently offline cyril jourdaFriend
I cannot delete a Job in Hudson.
I have the following message :
"Checking if the job can be deleted .."
but the job is never deleted
Can anyone help me?
Thank you!
Re: Hudson 3.0.1 : I cannot delete a Job [message #1060210 is a reply to message #1060149] Thu, 23 May 2013 14:13 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 5/23/2013 6:58 AM, cyril jourda wrote:
> Hello,
> I have the following message : "Checking if the job can be deleted .."
> Can anyone help me?
> Thank you!
This forum answers questions on installing and using the Eclipse IDE.
Hudson is an Oracle product whose support is found elsewhere.
Re: Hudson 3.0.1 : I cannot delete a Job [message #1060220 is a reply to message #1060210] Thu, 23 May 2013 15:11 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Hudson is an Eclipse Project, which means it has its own forum as well (assuming no one follows up here). That forum can be found at http://eclipse.org/forums/eclipse.hudson .
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Hudson 3.0.1 : I cannot delete a Job [message #1060225 is a reply to message #1060220] Thu, 23 May 2013 15:22 Go to previous messageGo to next message
Oops, my bad. I didn't know that. I won't make this mistake again. Sorry.
Re: Hudson 3.0.1 : I cannot delete a Job [message #1060457 is a reply to message #1060225] Fri, 24 May 2013 18:53 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Cyril, can you check Hudson log to see if there are any error messages
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061345 is a reply to message #1060457] Fri, 31 May 2013 10:01 Go to previous messageGo to next message
Where i can find this log?? Hudson is deployed with Tomcat.
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061350 is a reply to message #1061345] Fri, 31 May 2013 10:09 Go to previous messageGo to next message
There is no info within the log about the "delete" action.
any idea?
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061413 is a reply to message #1061350] Fri, 31 May 2013 14:12 Go to previous messageGo to next message
There is no exception in the "Manage Hudson -> System Log?
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061669 is a reply to message #1061413] Mon, 03 June 2013 12:38 Go to previous messageGo to next message
Exactly there is no exception in the system log!
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061701 is a reply to message #1061669] Mon, 03 June 2013 14:24 Go to previous messageGo to next message
If that is the case, there may be some javascript error. Can you check through browser console to see if any javascript error reported. I usually use Firebug on Firefox.
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.0.1 : I cannot delete a Job [message #1061892 is a reply to message #1060149] Tue, 04 June 2013 14:35 Go to previous messageGo to next message
I just saw the same issue. The dialog showed red "Could not delete ..", but no log. I looked at the XHR Request/Response via Firebug and there was an exception sent by server (but dialog was not displaying). Turned out the thin backup plugin did not let the job folder to be deleted. So the error message. The dialog should be much more explanatory. Could you file a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Hudson
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.0.1 : I cannot delete a Job [message #1062024 is a reply to message #1061892] Wed, 05 June 2013 13:09 Go to previous messageGo to next message
Please find hereafter the Firebug error raised : <html><head><title>Apache Tomcat/6.0.35 - Rapport d'erreur</title><style><!--H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}A.name {color : black;}HR {color : #525D76;}--></style> </head><body><h1>Etat HTTP 404 - /job/toto/2/api/json</h1><HR size="1" noshade="noshade"><p><b>type</b> Rapport d'état</p><p><b>message</b> <u>/job/toto/2/api/json</u></p><p><b>description</b> <u>La ressource demandée (/job/toto/2/api/json) n'est pas disponible.</u></p><HR size="1" noshade="noshade"><h3>Apache Tomcat/6.0.35</h3></body></html>
Re: Hudson 3.0.1 : I cannot delete a Job [message #1062394 is a reply to message #1062024] Fri, 07 June 2013 14:10 Go to previous messageGo to next message
Any idea??
Re: Hudson 3.0.1 : I cannot delete a Job [message #1063059 is a reply to message #1062394] Wed, 12 June 2013 01:38 Go to previous message
Are you not able to delete any of the jobs or just this one job. In the error message you send I see
Looks like build 2 of job toto is not found. So I'm not sure if this error message is related to job delete.
Winston Prakash
Eclipse Hudson team
Previous Topic:Hudson console parsing documentation
Next Topic:Executing commands from a program spawned by hudson shell or batch file
Current Time: Tue Apr 16 18:01:17 GMT 2024
Powered by FUDForum. Page generated in 3.84359 seconds
