Home » Modeling » Papyrus » Extension point & stereotype & pallete
Extension point & stereotype & pallete [message #1059860] Wed, 22 May 2013 00:51 Go to next message
Noelia as is currently offline Noelia asFriend
I have created several prefiles for different elements, and I have created custom palettes with stereotype of these profiles, the problem is that for the element called extension point when i create a palette with stereotypes, these are not actually applied in the use case diagram, although the element is drawn .. Does anyone know if in this respect there is a problem with the element called extension point?
Thanks. Noelia.
Re: Extension point & stereotype & pallete [message #1059947 is a reply to message #1059860] Wed, 22 May 2013 10:10 Go to previous messageGo to next message
Leila A is currently offline Leila AFriend
Hej,
Did you create palette programmatically?
RegardsLeila
Re: Extension point & stereotype & pallete [message #1059975 is a reply to message #1059947] Wed, 22 May 2013 12:14 Go to previous messageGo to next message
I have continued this manual to do the palette:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CDcQFjAB&url=http%3A%2F%2Fdev.eclipse.org%2Fsvnroot%2Fmodeling%2Forg.eclipse.mdt.papyrus%2Ftrunk%2Fdoc%2FDevelopperDocuments%2FHow-To%2FPapyrusDevelopperTutorial_OnPaletteCustomization_v1.0_d2010-05-10.odt&ei=ObOcUeP2FYXy7AaX2YDoAw&usg=AFQjCNGSZR9A41zmKEafxm_r9uOguGBcgw&sig2=pWAPvCmwlelxHGQpRebKFw&bvm=bv.46751780,d.ZGU
Re: Extension point & stereotype & pallete [message #1066740 is a reply to message #1059975] Thu, 04 July 2013 07:50 Go to previous messageGo to next message
Dennis Stampfer is currently offline Dennis StampferFriend
I have a similar problem: I have a device stereotyped with no additional properties (yet). When I draw an device and apply the stereotype via properties->profile->... it works fine and the stereotype is applied. However, when I use the customization palette, the stereotype is not applied.
I tried it with classes before and it worked. I cannot make stereotype application from palette work with devices or artifacts.
Any news on this? I followed the tutorial mentioned above.
thanks
Re: Extension point & stereotype & pallete [message #1070122 is a reply to message #1066740] Wed, 17 July 2013 09:22 Go to previous message
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=412476
Previous Topic:Customized Palette for Stereotypes with String Properties
Next Topic:How to specify flow condition in activity diagrams
Current Time: Tue Apr 16 18:17:14 GMT 2024
Powered by FUDForum. Page generated in 1.38479 seconds
