Home » Archived » Buckminster » problems when running emma in Jenkins
problems when running emma in Jenkins [message #1059464] |
Sun, 19 May 2013 05:05  |
I've just started using emma in my buckminster builds in Jenkins.
First of all, I run emma as follows
emma -l "mylaunch.launch" --output
"${buckminster.output.root}/test.results/mylaunch.launch.xml" --xml
"${buckminster.output.root}/test.results/coverage.mylaunch.launch.xml"
--flatXML --stdout --stderr
and I run buckminster from ant (I tested this both with Buckminster
headless 4.2 and 4.3).
When I run the ant script locally on my machine, everything works file
and coverage.mylaunch.launch.xml is created.
When I run the same ant script in Jenkins, I get this error when the
junit test suite ends
[java] INFO: Starting test session TraitJTypingUtilTest
[java] INFO: Running test...
[java] INFO: ...OK [0.201s]
[java] INFO: Tests finished.
[java] INFO: Elapsed time: 1.556 seconds.
[java] INFO: Total number of tests executed: 2
[java] INFO: Successful tests: 2
[java] INFO: Failed tests: 0
[java] INFO: Errors: 0
[java] INFO: Ignored tests: 0
[java] INFO: Overall status: OK
[java] ERROR: No coverage has been collected during coverage launch
(code 5101).
the strange thing is that most of the time the
coverage.mylaunch.launch.xml is actually created (in spite of the ERROR
above)...
when the job executes the postbuild action of the Emma plugin in Jenkins
"Record Emma coverage report", the coverage.mylaunch.launch.xml is
found, but I always get this error
hudson.util.IOException2: Failed to read
/usr/share/tomcat6/.jenkins/workspace/my.project/buildroot/buckminster.output/test.results/coverage.mylaunch.launch.xml
at hudson.tasks.junit.TestResult.parse(TestResult.java:284)
at hudson.tasks.junit.TestResult.parsePossiblyEmpty(TestResult.java:223)
Caused by: org.dom4j.DocumentException:
/usr/share/tomcat6/.jenkins/workspace/my.project/buildroot/buckminster.output/test.results/report.dtd
(No such file or directory) Nested exception:
/usr/share/tomcat6/.jenkins/workspace/xtext-traitj-gerrit-ant/buildroot/buckminster.output/test.results/report.dtd
which seems to imply that it's trying to read the report.dtd...
anyone else experiencing this?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Re: problems when running emma in Jenkins [message #1059840 is a reply to message #1059464] |
Tue, 21 May 2013 16:19   |
Hi Lorenzo,
There's been lots of changes in this area when we switched to a more
recent version of Emma. Your case is fairly special though, and I don't
know how to help. If you do further findings, and/or if you can attach
something that can be easily reproduced to a bug report, then I'll look
into it.
- thomas
On 2013-05-19 11:05, Lorenzo Bettini wrote:
> Hi
> (code 5101).
> above)...
> thanks in advance
> Lorenzo
Re: problems when running emma in Jenkins [message #1059850 is a reply to message #1059840] |
Tue, 21 May 2013 18:33   |
Hi Thomas
I made some progresses: first of all, I had not realized that EclEmma
(on which Buckminster relies for the 'emma', as far as I understand) is
now based on Jacoco, thus, in Jenkins, I need to use the Jacoco plugin,
and not the Emma plugin; the Jacoco plugin, in order to generate the
report, requires .exec files instead of .xml, thus I need to use the command
"${buckminster.output.root}/test.results/mylaunch.launch.xml" --exec
"${buckminster.output.root}/test.results/coverage.mylaunch.launch.exec"
and then the Jacoco plugin can deal with the generated exec files :)
the problem which remains is the
(code 5101).
as I said, the strange thing is that most of the time the
coverage.mylaunch.launch.exec is actually created (in spite of the ERROR
above)... sometimes though, the whole build fails due to this error...
I run the emma command twice in my build: the first command deals with
plain Junit tests, the second command deals with Plug-in Junit tests...
the second command does not report the above error... I'll try to
investigate further, possibly with other projects, and keep you posted.
Concerning the "report.dtd" problem it was my fault: I was trying to
archive the coverage.xml as a Junit report ;)
In any case, the .xml generated by jacoco is simply not compatible with
Jenkins Emma Plugin: when using the new EclEmma, you need to use Jenking
Jacoco Plugin anyway.
cheers
Lorenzo
On 05/21/2013 10:19 PM, Thomas Hallgren wrote:
> Hi Lorenzo,
> into it.
> - thomas
>> Hi
>> (code 5101).
>> above)...
>> at
>> thanks in advance
>> Lorenzo
Re: problems when running emma in Jenkins [message #1060440 is a reply to message #1059850] |
Fri, 24 May 2013 12:07   |
Hi Thomas,
here's some other collected info
> (code 5101).
by looking at buckminster code, Emma.java, I see that in case there is
no coverage session, buckminster throws an exception with message "No
coverage sessions found", while the above error is issued by eclemma
itself, and the faq (http://www.eclemma.org/faq.html#trouble01) says
"This happens when the Java process did not terminate properly, e.g. has
been manually killed with the Terminate button. Make sure your program
terminates on its own. "
indeed, the buckminster's emma command terminates, in fact, by using
DEBUG I see
INFO: Elapsed time: 69.02 seconds.
INFO: Total number of tests executed: 113
INFO: Successful tests: 113
INFO: Errors: 0
ERROR: No coverage has been collected during coverage launch (code 5101).
Doing full workspace refresh
Waiting for jobs to end
thus, I assume the buckminster command terminates correctly, but
internally EclEmma issues that error because its Java process is
terminated before it has finished?
If I run plain junit test suite and the plug-in junit test suite, the
first suite reports this error
If I run plug-in junit test suite first and then plain junit test suite,
none of them reports this error
when the error is reported, the coverage.xml file is generated anyway
(most of time, when it's not generated, buckminster itself fails).
Can it be due to some synchronization issues when buckminster runs
eclemma and does not wait for it to terminate?
The above problem happens in a Jenkins server, which is almost 10 years
old, thus not very powerful...
shall I file a bug report?
cheers
Lorenzo
>> Hi Lorenzo,
>> into it.
>> - thomas
>>> Hi
>>> (code 5101).
>>> above)...
>>> at
>>> thanks in advance
>>> Lorenzo
Current Time: Tue Jul 08 18:05:23 EDT 2025
Powered by FUDForum. Page generated in 0.24827 seconds
