Home » Modeling » Papyrus » Critical Exception in latest M7 build
Critical Exception in latest M7 build [message #1059286] Thu, 16 May 2013 07:17 Go to next message
Marc-Florian Wendland is currently offline Marc-Florian WendlandFriend
Member
Hi guys,
have you ever been encountered this exception (se down below) lately?
It first appeared when I tried to save the model, thus, saving was no longer
possible.
Marc-Florian
eclipse.buildId=4.3.0.I20130502-0800
java.version=1.7.0_17
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data
E:\workspaces\fokusmbt\trunk/../runtimes/kepler -dev
file:E:/workspaces/fokusmbt/trunk/.metadata/.plugins/org.eclipse.pde.core/keplerMigration/dev.properties
-os win32 -ws win32 -arch x86_64 -consoleLog
Warning
Thu May 16 09:10:44 CEST 2013
Save Failed
java.lang.LinkageError: com/google/common/base/Optional
at
org.eclipse.papyrus.uml.controlmode.profile.ControlledElementReadOnlyHandler.anyReadOnly(ControlledElementReadOnlyHandler.java:65)
at
org.eclipse.papyrus.infra.emf.readonly.ReadOnlyManager.anyReadOnly(ReadOnlyManager.java:159)
at
org.eclipse.papyrus.infra.core.resource.ModelSet.save(ModelSet.java:652)
at
org.eclipse.papyrus.infra.core.lifecycleevents.SaveAndDirtyService.doSave(SaveAndDirtyService.java:275)
at
org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.doSave(CoreMultiDiagramEditor.java:798)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper.java:151)
at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper.java:274)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at
org.eclipse.ui.internal.WorkbenchWindow$13.run(WorkbenchWindow.java:1715)
at
org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1712)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:282)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:261)
at
org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:156)
at
org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.doSave(CompatibilityPart.java:421)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:237)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:201)
at
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:90)
at
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.savePart(PartServiceImpl.java:1215)
at
org.eclipse.ui.internal.WorkbenchPage.saveAllEditors(WorkbenchPage.java:3480)
at
org.eclipse.ui.internal.WorkbenchPage.saveAllEditors(WorkbenchPage.java:3434)
at org.eclipse.ui.internal.SaveAllAction.run(SaveAllAction.java:137)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1109)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:993)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Re: Critical Exception in latest M7 build [message #1059287 is a reply to message #1059286] Thu, 16 May 2013 12:16 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
I've never seen a linkage error that wasn't a subclass of LinkageError
(e.g., UnsupportedClassVersionError, AbstractMethodError,
NoSuchMethodError)
This looks like a symptom of the multiple versions of the Google Guava
library being published in the Kepler repo that was raised on the
cross-project issues mailing list. How many versions of
com.google.guava do you have installed, and which is Papyrus wired to?
Perhaps it is the 12.0 version that requires a later JRE than what you
are using.
HTH,
Christian
On 2013-05-16 07:17:50 +0000, Marc-Florian Wendland said:
> Hi guys,
> longer possible.
> Regards,
> Marc-Florian
> java.vendor=Oracle Corporation
> Warning
> Save Failed
> at
> at
> at org.eclipse.papyrus.infra.core.resource.ModelSet.save(ModelSet.java:652)
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1712)
> at
> at
> at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:156)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> at
> at
> at
> at
> at
> at
Re: Critical Exception in latest M7 build [message #1059288 is a reply to message #1059287] Thu, 16 May 2013 12:27 Go to previous messageGo to next message
There are similarities to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407686, which I have
RESOLVED WORKSFORME since it went away.
The hazard is that Guava 12 mandates Java 1.6 and is new in Orbit for
M7. However most projects only lower bound Guava at 10.0 so work happily
with whatever comes along.
I think the problem arises if you have a 1.5 JRE available as well as
something more recent. P2 can then install 1.6 only plugins leaving a
hidden problem if a 1.5 launch occurs. This can occur predictably for a
JUnit/application launch with a 1.5 JRE.
The loophole that somehow allows 1.5 usage for plugins is in need of
discovery. Perhaps it's somehow due to a historic build.
Ed Willink
On 16/05/2013 13:16, Christian W. Damus wrote:
> NoSuchMethodError)
> to? Perhaps it is the 12.0 version that requires a later JRE than
> what you are using.
> HTH,
> Christian
>> Hi guys,
>> longer possible.
>> Regards,
>> Marc-Florian
>> Warning
>> Save Failed
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Critical Exception in latest M7 build [message #1059289 is a reply to message #1059288] Thu, 16 May 2013 12:48 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407686 reopened since
Guava imports are dangerously inconsistent.
Ed Willink
On 16/05/2013 13:27, Ed Willink wrote:
> Hi
Re: Critical Exception in latest M7 build [message #1059290 is a reply to message #1059289] Thu, 16 May 2013 14:20 Go to previous messageGo to next message
Member
Hi guys,
thanks indeed for the help. It was a Guava Version conflict...
Sorry for posting, I should have investigate potential failure causes more
thoroughly.
Marc-Florian
"Ed Willink" wrote in message news:kn2kjg$sqf$1@xxxxxxxxe.org...
Ed Willink
> Hi
Re: Critical Exception in latest M7 build [message #1059292 is a reply to message #1059290] Fri, 17 May 2013 01:45 Go to previous message
Don't apologize for posting. You've helped to raise the profile of a
serious problem!
cW
On 2013-05-16 14:20:11 +0000, Marc-Florian Wendland said:
> Hi guys,
> more thoroughly.
> Regards,
> Marc-Florian
> Hi
> Regards
> Ed Willink
>> Hi
Previous Topic:Class Diagram with inner classes
Next Topic:Extending the SysML Datamodel
Current Time: Mon Aug 10 19:28:52 GMT 2020
Powered by FUDForum. Page generated in 0.02259 seconds
