Home » Archived » BIRT » How to calculate elapsed time?
How to calculate elapsed time? [message #1059000] Thu, 16 May 2013 03:41 Go to next message
I have tickets with submit date and closed date.
I wish to calculate the total time elapsed between submission and closure of the ticket.
The entries in those columns are in following format:
May 10, 2013 6:15 PM
Also some tickets are not closed so there entries are blank. Also let me know how to calculate for the same.
i want the elapsed time column to appear as a separate column in report.
please help...
and thanks in advance...
Re: How to calculate elapsed time? [message #1059143 is a reply to message #1059000] Thu, 16 May 2013 20:42 Go to previous messageGo to next message
You should be able to create a computed column and use this function to get the seconds between your two dates:
BirtDateTime.diffSecond(date1,date2)
From there, you can use the elapsed seconds value to display what you'd like.
Re: How to calculate elapsed time? [message #1059164 is a reply to message #1059143] Fri, 17 May 2013 01:15 Go to previous messageGo to next message
thank you...
can i calculate the time in HH:MM format..as in exact hours and mins...??
Re: How to calculate elapsed time? [message #1059165 is a reply to message #1059164] Fri, 17 May 2013 02:05 Go to previous message
If you took the seconds from above, you could easily create this format with something like the following as your expression for you type string computed column:
remainingSeconds = BirtDateTime.diffSecond(date1,date2);
Hours = Math.floor(remainingSeconds/3600);
remainingSeconds = remainingSeconds%3600;
Minutes = Math.floor(remainingSeconds/60);
remainingSeconds = remainingSeconds%60;
colOutput = Hours + ":" + Minutes + ":" + remainingSeconds;
colOutput;
Previous Topic:BIRT ignores alias when generating column binding names for joint data sets
Next Topic:custom format x-axis and y-axis label in chart by script
Current Time: Wed Apr 23 12:03:38 EDT 2025
Powered by FUDForum. Page generated in 0.07299 seconds
