Home » Eclipse Projects » NatTable » ComboBoxCellEditor keyboard navigation
ComboBoxCellEditor keyboard navigation [message #1058839] Wed, 15 May 2013 11:28 Go to next message
Steve Kramer is currently offline Steve KramerFriend
The ComboBoxCellEditor in NatTable 1.0.0 seems to close the drop down box immediately whenever the user hits the UP or DOWN arrow key once. This prevents the user from cycling through all the choices in the drop down box via the keyboard only. In other words if the user wants to select a different choice he's almost required to use the mouse.
Is there a way the ComboBoxCellEditor allows the user to make a selection strictly with the keyboard using the up/down arrows and possibly the space bar/enter keys ?
Steve
Re: ComboBoxCellEditor keyboard navigation [message #1058875 is a reply to message #1058839] Wed, 15 May 2013 13:51 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
thanks for reporting this. This is indeed a bug regarding multiple selections and checkbox support in ComboBoxCellEditor. Of course key navigation should be supported as expected.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=408130
I fixed this bug immediately as we are close before release. There should be soon a new SNAPSHOT be available containing the fix. It would be great if you could update and test if everything works correctly now.
Dirk
Re: ComboBoxCellEditor keyboard navigation [message #1059023 is a reply to message #1058875] Thu, 16 May 2013 09:18 Go to previous message
Hi Dirk
Verified against SNAPSHOT 130 and works fine.
Steve
Previous Topic:Unable to get RowHideShowLayer from body layer stack of nattable.
Next Topic:how to change filter list without effecting the change in event list?
Current Time: Mon Jan 20 07:05:10 GMT 2020
Powered by FUDForum. Page generated in 0.01978 seconds
