Re: Creating an OCLExpression expensive? [message #1059272 is a reply to message #1058834] |
Wed, 15 May 2013 11:01 |
Ed Willink Messages: 7655 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi<br>
<br>
Further to my response to a less detailed question on the OCL
newsgroup.<br>
<br>
From the OCL documentation:<br>
<br>
<div class="titlepage">
<div>
<div>
<h2 style="clear: both;" class="title"><a name="Standalone"></a>Ecore/UML
Standalone Configuration</h2>
</div>
</div>
</div>
<p>If you use Eclipse OCL within Eclipse you should find that the
appropriate registrations are provided for you automatically by
the plugin registration mechanisms.</p>
<p>However if you use Eclipse OCL outside Eclipse, for instance in
JUnit tests, you must provide the corresponding registrations in
your code.</p>
<div class="section" title="Ecore">
<div>
<div>
<h3 class="title"><a name="Ecore"></a>Ecore</h3>
</div>
</div>
</div>
<p>For the Ecore metamodel, the required registrations should be
provided by invoking <code class="code">org.eclipse.ocl.ecore.OCL.initialize(ResourceSet)</code>.</p>
</div>
---<br>
<br>
I see no use of <code class="code">OCL.initialize</code> so I
suspect that you are incurring Internet failures on unregistered
nsURIs.<br>
<br>
Regards<br>
<br>
Ed Willink<br>
<br>
<br>
On 15/05/2013 11:50, Kosala Yapa wrote:
<blockquote cite="mid:kmvp9l$ul7$1@xxxxxxxxe.org" type="cite">Hi
there,
<br>
<br>
Here is my XML model:
<br>
<br>
<br>
<Device xmlns="model" xmi:version="2.0"
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a> name="dd"
comment="">
<br>
<HeadModule orderNumber="328061"/>
<br>
<Modules xsi:type="Module" number="1" deviceType="49157"
orderNumber="328095"/>
<br>
<Modules xsi:type="Module" number="2" deviceType="49157"
<br>
<Modules xsi:type="Module" number="3" deviceType="49157"
<br>
<Modules xsi:type="Module" number="4" deviceType="49157"
<br>
<Modules xsi:type="Module" number="5" deviceType="49157"
<br>
<Modules xsi:type="Module" number="6" deviceType="49157"
<br>
<Modules xsi:type="Module" number="7" deviceType="49157"
<br>
<Modules xsi:type="Module" number="8" deviceType="49157"
<br>
<Modules xsi:type="Module" number="9" deviceType="15"
orderNumber="328301"/>
<br>
<Modules xsi:type="Module" number="10" deviceType="15"
<br>
<Modules xsi:type="NullModule" number="11"/>
<br>
<Modules xsi:type="NullModule" number="12"/>
<br>
<BackPlanes orderNumber="321702"/>
<br>
<br>
<br>
</Device>
<br>
<br>
<br>
<br>
I create an OCL query and execute that over an EObject called
Device (above XML EObject).
<br>
<br>
Sample code:
<br>
// create OCL instance for Ecore
<br>
OCL ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
<br>
<br>
// create OCL helper
<br>
OCLHelper<EClassifier, EOperation, EStructuralFeature,
Constraint> helper = ocl
<br>
createOCLHelper();
<br>
<br>
// set OCL context classifier
<br>
helper.setContext(ModelPackage.Literals.DEVICE);
<br>
helper.setInstanceContext(ModelPackage.Literals.DEVICE__MODULES);
<br>
helper.setInstanceContext(device);
<br>
<br>
// create query
<br>
OCLExpression<EClassifier> query = helper
<br>
createQuery("self.Modules->select(m|m.number<>null)->size()");
<br>
<br>
// use the query expression parsed before to create a Query
<br>
Query eval = ocl.createQuery(query);
<br>
int result = (Integer) eval.evaluate(device);
<br>
<br>
<br>
This is working fine, but helper.createQuery() statement takes
about 20 seconds. Am I doing something wrong in this code? or
Someone has a solution to this issue?
<br>
<br>
<br>
Thanks in advance.
<br>
Kosala
<br>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.02129 seconds
