Standalone scout project error at starting client [message #1058767] |
Wed, 15 May 2013 01:21 |
Sebastian Boccardi Messages: 47 Registered: September 2012 Location: Montevideo |
Member |
I've been trying the standalone howto. So i managed to get the application running but there is an error at startup:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-05-14 22:13:19.235
!MESSAGE Unable to create class 'org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon' from bundle '69'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.bindings.EBindingService.createBinding(Lorg/eclipse/jface/bindings/TriggerSequence;Lorg/eclipse/core/commands/ParameterizedCommand;Ljava/lang/String;Ljava/util/Map;)Lorg/eclipse/jface/bindings/Binding;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/e4/ui/workbench/swt/util/BindingProcessingAddon, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/bindings/EBindingService, have different Class objects for the type org/eclipse/jface/bindings/Binding used in the signature
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
Caused by: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.bindings.EBindingService.createBinding(Lorg/eclipse/jface/bindings/TriggerSequence;Lorg/eclipse/core/commands/ParameterizedCommand;Ljava/lang/String;Ljava/util/Map;)Lorg/eclipse/jface/bindings/Binding;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/e4/ui/workbench/swt/util/BindingProcessingAddon, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/bindings/EBindingService, have different Class objects for the type org/eclipse/jface/bindings/Binding used in the signature
at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.createBinding(BindingProcessingAddon.java:216)
at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBinding(BindingProcessingAddon.java:142)
at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBindingTable(BindingProcessingAddon.java:132)
And the application fails when trying to fill a field for a search and things like that. With the next error:
!ENTRY org.eclipse.ui 4 0 2013-05-14 22:19:32.592
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name "org/eclipse/swt/widgets/Event"
at org.eclipse.jface.bindings.keys.SWTKeySupport.convertEventToUnmodifiedAccelerator(SWTKeySupport.java:95)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.generatePossibleKeyStrokes(KeyBindingDispatcher.java:142)
Anyone had the same experience with that particular howto?
Sebastian
FUDForum. Page generated in 0.02843 seconds
