Re: Xtext 1.0.2 [message #1058880 is a reply to message #1058445] |
Wed, 15 May 2013 14:12 |
Risheek Rajolu Messages: 3 Registered: May 2013 |
When I do that, I get the following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Xtext UI 1.0.2.v201102150722 (org.eclipse.xtext.ui.feature.group 1.0.2.v201102150722)
Missing requirement: Xtext UI 1.0.2.v201102150722 (org.eclipse.xtext.ui.feature.group 1.0.2.v201102150722) requires 'org.eclipse.xpand.ui.feature.group [1.0.1,1.1.0)' but it could not be found
If I deselect Xtext UI (I do not think I need it), I get the following errors:
Software being installed: Xtext Examples 1.0.2.v201102150722 (org.eclipse.xtext.examples.feature.group 1.0.2.v201102150722)
Cannot satisfy dependency:
From: Xtext Examples 1.0.2.v201102150722 (org.eclipse.xtext.examples.feature.group 1.0.2.v201102150722)
To: org.eclipse.xtext.ui.feature.group [1.0.1,1.1.0)
If I deselect Xtext examples too (this too, I do not think necessary), I get the following errors:
Software being installed: Xtext SDK 1.0.2.v201102150722 (org.eclipse.xtext.sdk.feature.group 1.0.2.v201102150722)
From: Xtext SDK 1.0.2.v201102150722 (org.eclipse.xtext.sdk.feature.group 1.0.2.v201102150722)
To: org.eclipse.xtext.examples.feature.group [1.0.2.v201102150722]
I have no idea what the problem is, do you know?
Re: Xtext 1.0.2 [message #1059257 is a reply to message #1059133] |
Fri, 17 May 2013 05:12 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
Sounds like the wrong version of Google Guava.
Am 17.05.13 01:45, schrieb Risheek Rajolu:
> I tried also doing xpand along with that and it did not complain!
> However, when I install it and Canappi and open something it says:
> java.lang.NoClassDefFoundError: com/google/inject/internal/Maps
> at
> org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.<init>(AbstractInternalAntlrParser.java:185)
> at
> com.canappi.metamodels.mdsl.parser.antlr.internal.InternalMDslParser.<init>(InternalMDslParser.java:41)
> at
> com.canappi.metamodels.mdsl.parser.antlr.internal.InternalMDslParser.<init>(InternalMDslParser.java:59)
> at
> com.canappi.metamodels.mdsl.parser.antlr.MDslParser.createParser(MDslParser.java:40)
> at
> com.canappi.metamodels.mdsl.parser.antlr.MDslParser.parse(MDslParser.java:26)
> at
> org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:57)
> at
> org.eclipse.xtext.parser.AbstractParser.parse(AbstractParser.java:46)
> at
> org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:146)
> at
> org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:63)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
> at
> org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.loadResource(XtextDocumentProvider.java:120)
> at
> org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:103)
> at
> org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:229)
> at
> org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:735)
> at
> org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:131)
> at
> org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:400)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4222)
> at
> org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:237)
> at
> org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1480)
> at
> org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
> at
> org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:149)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3209)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
> at
> org.eclipse.ui.internal.WorkbenchWindow$13.run(WorkbenchWindow.java:1679)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1676)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3227)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3254)
> at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:169)
> at
> org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:360)
> at
> org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:301)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
> at
> org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
> at
> org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
> at
> org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
> at
> org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
> at org.eclipse.swt.widgets.Display.syncExec(Display.java:4607)
> at
> org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
> at
> org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
> at
> org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
> at
> org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
> at
> org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
> at
> org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
> at
> org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
> at
> org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
> at
> org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
> at
> org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
> at
> org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
> at
> org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:422)
> at
> org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:389)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:606)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1029)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3047)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:2969)
> at
> org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2951)
> at
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2947)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2911)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2902)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
> at
> org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
> at
> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
> at
> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
> at
> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
> at
> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4136)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1271)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3982)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at
> at
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
> Caused by: java.lang.ClassNotFoundException:
> com.google.inject.internal.Maps
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
> ... 136 more
> Do you know where this problem is arising from?
Get professional support from the Xtext committers at www.typefox.io
FUDForum. Page generated in 0.03967 seconds
