Home » Archived » BIRT » I use birt 2.3.2 which Tribix xls emitter version should I use?(I have tried version 2.3.1 look weird )
I use birt 2.3.2 which Tribix xls emitter version should I use? [message #1058315] Mon, 13 May 2013 14:33 Go to next message
Tanakorn Triniti is currently offline Tanakorn TrinitiFriend
I have tried version 2.3.1 look weird like some cells are marged while birt original emitter works properly but it is xml spreedsheet 2003 which cannot work with excel reader on another program.
Re: I use birt 2.3.2 which Tribix xls emitter version should I use? [message #1058425 is a reply to message #1058315] Tue, 14 May 2013 05:23 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
That's likely the best version of Tribix to use for your version. The source is available if you want to try to modify it to work better for you.
Other options you might try from recent contests on BIRT Exchange are:
BIRT Exchange DevShare - Native Excel Emitter Plug-in
AND
BIRT Exchange - SpudSoft BIRT Excel Emitter
Not sure if they'll work in your older version, but you might give them a try.
Michael
Developer Evangelist, Silanis
Re: I use birt 2.3.2 which Tribix xls emitter version should I use? [message #1058434 is a reply to message #1058425] Tue, 14 May 2013 06:02 Go to previous messageGo to next message
Thank you Michael. I will try them.
Re: I use birt 2.3.2 which Tribix xls emitter version should I use? [message #1058773 is a reply to message #1058434] Wed, 15 May 2013 02:34 Go to previous message
You're welcome. Let me know if either work. I've not tried them in older versions. I'd be interested to know.
Michael
Previous Topic:Birt 4.2.0 with Eclipse juno and Jboss 6.1.0 final
Next Topic:BIRT Scripted data source
Current Time: Wed Sep 27 12:56:53 GMT 2023
Powered by FUDForum. Page generated in 0.01467 seconds
