Home » Eclipse Projects » SWTBot » Library.xml not exist in swtbot 2.1(Library.xml not exist in swtbot 2.1)
Re: Library.xml not exist in swtbot 2.1 [message #1058234 is a reply to message #1058212] |
Mon, 13 May 2013 09:57 |
gourav mehta Messages: 9 Registered: June 2012 |
Thanks Mickael for your prompt reply. I extracted the bundle and run the test cases through ant script but i am getting below error
java.lang.RuntimeException: Application "org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview, org.eclipse.swtbot.eclipse.core.swtbottestapplication, org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
at org.eclipse.core.launcher.Main.main(Main.java:34)
Re: Library.xml not exist in swtbot 2.1 [message #1058245 is a reply to message #1058212] |
Mon, 13 May 2013 10:38 |
I have changed in library.xml file from
to
Now i m getting some other message in logs:
Caused an ERROR
java.lang.Exception: Could not find plugin "com.testing.test"
org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "com.testing.test"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.runFailed(EclipseTestRunner.java:289)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:242)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.<init>(EclipseTestRunner.java:222)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.run(EclipseTestRunner.java:206)
at org.eclipse.swtbot.eclipse.junit.headless.UITestApplication.runTests(UITestApplication.java:116)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.Exception: Could not find plugin "com.testing.test"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.loadSuiteClass(EclipseTestRunner.java:303)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:239)
But com.testing.test.jar is already in plugins folder.
Any clue ?
[Updated on: Mon, 13 May 2013 10:39] Report message to a moderator
Re: Library.xml not exist in swtbot 2.1 [message #1058395 is a reply to message #1058245] |
Mon, 13 May 2013 21:39 |
> to org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication
That was the right move. You should consider contributing that change to
SWTBot: http://wiki.eclipse.org/SWTBot/Contributing
> Caused an ERROR
Is com.testing.test your test bundle? If yes, did you make sure it's
available in the instance of Eclipse you're using to test? Ideally, you
should have it installed in your test app using p2 director so you get
sure it's installed with all its dependencies.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Current Time: Thu Apr 25 21:33:46 GMT 2024
Powered by FUDForum. Page generated in 0.03925 seconds
