Home » Modeling » Papyrus » Update of PapyrusPalettePreferences?
Update of PapyrusPalettePreferences? [message #1058104] Sat, 11 May 2013 10:42 Go to next message
Marc-Florian Wendland is currently offline Marc-Florian WendlandFriend
Member
Hi Papyrus-Team,
recently I started migrating our tool (based on Papyrus 0.8.2 and Indigo) to
the Kepler release of Papyrus. Although almost everything in the
architecture was refactored ever since, most of the things can be sorted out
rather easily.
However, I was not able to find the exact location where the palettes can be
set visible or hidden. In 0.8.2, there was this very convenient yet
intuitive PapyrusPalettePrefences class, which has obviously disappeared in
0.10 (most probably already in 0.9).
Can someone point me to a location where the functionality of
PapyrusPalettePreferences has been moved to, and briefly explain what has
essentially changed in showing/hiding palettes?
Thanks a lot
Marc-Florian
Re: Update of PapyrusPalettePreferences? [message #1059450 is a reply to message #1058104] Sat, 18 May 2013 18:05 Go to previous message
Member
Okay, problem solved.
I used PapyrusPalettePrefences and it worked as expected.
But why is the Palette-related stuff contained in
org.eclipse.papyrus.uml.diagram.common? Palette configuration is not
UML-specific, is it? This was also a reason, why I did not find the
corresponding implementation in the first place.
Marc-Florian
"Marc-Florian Wendland" wrote in message
news:kml7af$b1e$1@xxxxxxxxe.org...
Hi Papyrus-Team,
rather easily.
Thanks a lot
Marc-Florian
Previous Topic:(Programmatically) auto-generate Class-Diagram from existing UML-Model
Next Topic:Where are the Tabbed Property View extensions are defined?
Current Time: Mon Aug 10 16:08:12 GMT 2020
Powered by FUDForum. Page generated in 0.01518 seconds
