Home » Eclipse Projects » P2 » Update error
Update error [message #1057955] Fri, 10 May 2013 01:32 Go to next message
trying to update Kepler (4.3.0 I20130314-1330) to M7 but i always get an error dialog saying:
An error occurred while uninstalling
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Uninstall, operand=[R]org.eclipse.sdk.ide.executable.win32.win32.x86_64 4.3.0.I20130314-1330 --> null, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction).
Backup of file D:\installed\Eclipse\E_4.3_x64\eclipse.exe failed.
Can not remove : D:\installed\Eclipse\E_4.3_x64\eclipse.exe
My eclipse.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130225-1645.jar
-vm
D:/installed/Java/JDK_1.7_64bit/bin/javaw.exe
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20130228-0336
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-XX:+UnlockExperimentalVMOptions
-Xms128m
-Xmx1024m
Running Win7 64Bit with 64Bit JDK7u21 as administrator and i'm using updatesite "http://download.eclipse.org/eclipse/updates/4.3milestones".
My anti-virus has an exception for my hole eclipse folder.
I checked all handles (processes) using 'eclipse.exe' and there 'eclipse.exe' itself, 'java.exe' and 'csrss.exe' (Client/Server Runtime Subsystem from Windows, its used for the console and threading under Windows).
I found a bugreport https://bugs.eclipse.org/bugs/show_bug.cgi?id=333355 with the same issue but no solution for my case.
Has anybody an idea ho to solve this except of make a clean eclipse installation?
Thanks!
Re: Update error [message #1058194 is a reply to message #1057955] Mon, 13 May 2013 03:49 Go to previous messageGo to next message
You may have more luck asking in the P2 forums because you can see P2 complaining it can not remove a file. Initially looks like a permission issue but as you state it is not the case.
Re: Update error [message #1127916 is a reply to message #1057955] Mon, 07 October 2013 02:23 Go to previous messageGo to next message
I had same issue with updating Kepler. W7 with admin.
How to solve:
  1. Run eclipse
  2. Rename eclipse exe to eclipse.exe.back
  3. Run updates
  4. Updates executed successfully
Re: Update error [message #1238305 is a reply to message #1057955] Fri, 31 January 2014 19:14 Go to previous messageGo to next message
Thanks Premysl! Worked nicely, updating from 4.4M3 -> 4.4M5.
(First time I've seen that...)
Re: Update error [message #1385306 is a reply to message #1057955] Thu, 05 June 2014 09:48 Go to previous messageGo to next message
make a new workspace then try with the kepler. it doesnot work in old workspace. worked for me.
icon11.gif  Re: Update error [message #1517299 is a reply to message #1385306] Fri, 19 December 2014 06:58 Go to previous messageGo to next message
in the terminal
sudo exclipse
the problem is the program does not have permision to update the files
Re: Update error [message #1847343 is a reply to message #1127916] Sat, 23 October 2021 17:20 Go to previous messageGo to next message
Premysl Fiala wrote on Mon, 07 October 2013 06:23
How to solve:
  1. Run eclipse
  3. Run updates
Fixed my problem updating 2021-06 to 2021-09. As far as I can see, the permissions should be ok. Does eclipse use a different user account in the background?
Could the error message be reworked to give more details about the cause of not being able to move the old file?
Re: Update error [message #1848819 is a reply to message #1847343] Sat, 18 December 2021 02:35 Go to previous messageGo to next message
Johannes Unger wrote on Sat, 23 October 2021 21:20
How to solve:
  1. Run eclipse
  3. Run updates
same goes to me, using this trick works
Re: Update error [message #1849256 is a reply to message #1127916] Mon, 10 January 2022 08:23 Go to previous message
after renaming the eclipse.exe to eclipse.exe.back and running the updates, do we have to remove the eclipse.exe.back file after completing updates, as a new eclipse.exe file was created after the update.
so now there is a eclipse.exe file in my folder, and an eclipse.exe.back file as well.
Previous Topic:Resolving but not installing IUs on the command line
Next Topic:Install plugin no p2.director
Current Time: Fri Jul 18 13:56:28 EDT 2025
Powered by FUDForum. Page generated in 0.08439 seconds
